ip-mac [conflict|routing]
ip-mac conflict drop-only
ip-mac conflict [log-and-drop|log-only] log-level [<0-7>|alerts|critical|debug| emergencies|errors|informational|notifications|warnings]
ip-mac routing conflict drop-only
ip-mac routing conflict [log-and-drop|log-only] log-level [<0-7>|alerts|critical|debug| emergencies|errors|informational|notifications|warnings]
| conflict | Action performed when a conflict exists between the IP address and MAC address. This option is enabled by default. |
| drop-only | Drops a packet without logging |
| log-and-drop | Logs the event and drops the packet. This is the default setting. |
| log-only | Logs the event only, the packet is not dropped |
| log-level | Configures the log level |
| <0-7> | Sets the numeric logging level |
| alerts | Numerical severity 1. Indicates a condition where immediate action is required |
| critical | Numerical severity 2. Indicates a critical condition |
| debugging | Numerical severity 7. Debugging messages |
| emergencies | Numerical severity 0. System is unusable |
| errors | Numerical severity 3. Indicates an error condition |
| informational | Numerical severity 6. Indicates a informational condition |
| notification | Numerical severity 5. Indicates a normal but significant condition |
| warnings | Numerical severity 4. Indicates a warning condition. This is the default setting. |
| routing | Enables IPMAC routing conflict detection. This is also known as a Hole-196 attack in the network. This feature helps to detect if the client is sending routed packets to the correct router-mac-address. |
| conflict | Defines the action performed when a routing table conflict is detected. This option is enabled by default. |
| routing | Defines a routing table based action |
| conflict | Action performed when a conflict exists in the routing table. This option is enabled by default. |
| log-level | Configures the log level to log this event under |
nx9500-6C8809(config-fw-policy-testFW)#ip-mac conflict drop-only
         nx9500-6C8809(config-fw-policy-testFW)#ip-mac routing conflict log-and-drop log-level notifications
         nx9500-6C8809(config-fw-policy-testFW)#show context firewall-policy testFW ip dos fraggle drop-only ip dos tcp-sequence-past-window drop-only ip dos tcp-max-incomplete high 600 ip dos tcp-max-incomplete low 60 ip-mac conflict drop-only ip-mac routing conflict log-and-drop log-level notifications flow timeout icmp 16000 flow timeout udp 10000 flow timeout tcp established 1500 flow timeout other 16000 dhcp-offer-convert alg facetime dns-snoop entry-timeout 1200 nx9500-6C8809(config-fw-policy-testFW)#
| no | Disables actions based on device IP MAC table, IP address, and MAC address conflict detection |
