When coverage hole recovery is enabled, on detection of a coverage hole, Smart RF first determines the power increase needed based on the SNR (signal-to-noise ratio) for a client as seen by the access point radio. If a client‘s SNR is above the specified threshold, the transmit power is increased until the SNR falls below the threshold.
The coverage-hole-recovery parameters can be modified only if the sensitivity level is set to ‘custom‘. For more information, see sensitivity.coverage-hole-recovery {client-threshold|coverage-interval|interval|snr-threshold}
         coverage-hole-recovery {client-threshold [2.4GHz|5GHz|6GHz] <1-255>}
         coverage-hole-recovery snr-threshold (2.4GHz|5GHz|6GHz) <1-75>
coverage-hole-recovery coverage-interval (2.4GHz|5GHz|6GHz) <1-120>
         | client-threshold | Optional. Specifies the minimum number of clients associated to a radio in order to trigger coverage hole recovery. |
| 2.4GHz <1-255> | Specifies the minimum number of clients on the
                        2.4 GHz band
| 5GHz <1-255> | Specifies the minimum number of clients on the 5.0 GHz band
| 6GHz <1-255> | Specifies the minimum number of clients on the 6.0 GHz band
coverage-hole-recovery {coverage-interval|interval} [2.4GHz|5GHz] <1-120>
         | coverage-interval | Optional. Specifies the interval between the discovery of a coverage hole and the initiation of coverage hole recovery |
| interval | Optional. Specifies the interval at which coverage hole recovery is performed even before a coverage hole is detected |
| 2.4GHz <1-120> | The following keywords are common to the
                        ‘coverage-interval‘ and ‘interval‘ parameters:
 Note: coverage-interval – The default is 10
                           seconds. Note: interval – The default is 30 seconds. |
| 5GHz <1-120> | The following keywords are common to the ‘coverage-interval' and ‘interval' parameters:
 Note: coverage-interval – The default is 10 seconds. Note: interval – The default is 30 seconds. |
| 6GHz <1-120> | The following keywords are common to the ‘coverage-interval' and ‘interval' parameters:
| snr-threshold | Optional. Specifies the SNR threshold. This value is the SNR threshold for an associated client as seen by its associated AP radio. When the SNR threshold is exceeded, the radio increases its transmit power to increase coverage for the associated client. |
| 2.4GHz <1-75> | Specifies SNR threshold on the 2.4 GHz band
| 5GHz <1-75> | Specifies SNR threshold on the 5.0 GHz band
| 6GHz <1-75> | Specifies SNR threshold on the 6.0 GHz band
nx9500-6C8809(config-smart-rf-policy-test)#coverage-hole-recovery snr-threshold 2.4GHz 35
         nx9500-6C8809(config-smart-rf-policy-test)#show context smart-rf-policy test sensitivity custom assignable-power 2.4GHz max 20 assignable-power 2.4GHz min 8 channel-list 2.4GHz 1,12 channel-width 5GHz auto channel-width 2.4GHz auto area test channel-list 2.4GHz 1,2,3 avoidance-time dfs 300 coverage-hole-recovery snr-threshold 2.4GHz 35 nx9500-6C8809(config-smart-rf-policy-test)#
| no (smart-rf-policy-config-mode-command) | Disables recovery from coverage hole errors |
