network
      Assigns networks to specified areas
         (defines the OSPF interfaces and their associated area IDs)
            - Access Points — AP410i/e, AP460i/e,
               AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432,
               AP8533
Syntax
         network <IP/M> area [<0-4294967295>|<IP>]
      Parameters
                     | <IP/M> | Specifies an OSPF network address/mask value. Defines networks (IP
                        addresses and mask) participating in OSPF. |
                     | area [<0-4294967295>|<IP>] | Specifies an OSPF area, associated with the OSPF address range, in one
                        of the following formats:
                           <0-4294967295> –
                              Specifies a 32 bit OSPF area ID from 0 - 4294967295<IP> – Defines
                              an OSPF area ID in the form of an IPv4 address |
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#network 1.2.3.0/24 area 4.5.6.7
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
 router ospf
  area 0.0.0.4
  auto-cost reference-bandwidth 1
  default-information originate metric 1 metric-type 2
  ip default-gateway priority 1
