A T5 controller uses the IPX operating system to manage its connected radio devices, as opposed to the WiNG operating system used by wireless controllers and service platforms. However, a T5 controller, once enabled as a supported external device, can provide data to WiNG to assist in a T5‘s management within the WiNG supported subnet populated by both types of devices. The CPEs are the T5 controller managed radio devices using the IPX operating system. These CPEs use a DSL as their high speed Internet access mechanism using the CPE‘s physical wallplate connection and phone jack.
This setting is applicable only when this WLAN supports T5 controllers and their connected CPEs.t5-client-isolation
None
nx9500-6C8809(config-wlan-test)#t5-client-isolation
      nx9500-6C8809(config-wlan-test)#show context wlan test ssid test bridging-mode local encryption-type none authentication-type none t5-client-isolation nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Allows clients connecting to the WLAN to communicate with one another |
