Configures LDAP dead period interval
ldap-deadperiod <60-300>
| ldap-deadperiod <60-300> | Configures an LDAP dead period. When enabled, LDAP service allows the AP or controller to bind with the LDAP server and retrieve user details to match with user-defined role filters. The LDAP deadperiod is the interval between two consecutive attempts to bind with the LDAP server. To enable LDAP service, use the ldap-query command.
nx9500-6C8809(config-role-policy-test)#ldap-deadperiod 100
         nx9500-6C8809(config-role-policy-test)#show context role-policy test default-role use ip-access-list in test precedence 1 ldap-deadperiod 100 nx9500-6C8809(config-role-policy-test)#
| no (role-policy-config-mode-command) | Removes or resets the LDAP deadperiod interval |
