Enables support for accounting messages for this captive portal
When enabled, accounting for clients entering and exiting the captive portal is initiated. Accounting is the method of collecting and sending security server information for billing, auditing, and reporting user data. This data includes information, such as start and stop times, executed commands (such as PPP), number of packets and number of bytes transmitted etc. Accounting enables tracking of captive portal services consumed by clients.
accounting [radius|syslog]
accounting radius
accounting syslog host <IP/HOSTNAME> {port <1-65535>} {proxy-mode [none|through-controller|through-rf-domain-manager]}
      accounting radius
| radius | Enables support for RADIUS accounting messages. When enabled, this option uses an external RADIUS resource for AAA accounting. This option is disabled by default. |
         | syslog host <IP/HOSTNAME> | Enables support for syslog accounting messages. When enabled, data relating to wireless client usage of remote access services is logged on the specified external syslog resource. This information assists in differentiating between local and remote users. Remote user information can be archived to an external location for periodic network and user administration. This option is disabled by default.
| port <1-65535> | Optional. Specifies the syslog server‘s listener port
| proxy-mode [none| through-controller| through-rf-domain-manager] | Optional. Specifies the mode of proxying the syslog server
nx9500-6C8809(config-captive-portal-test)#accounting syslog host 172.16.10.13 port 1
         nx9500-6C8809(config-captive-portal-test)#show context captive-portal test access-type logging access-time 35 accounting syslog host 172.16.10.13 port 1 nx9500-6C8809(config-captive-portal-test)#
| Disables accounting records for this captive portal |
