duplex
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Parameters
duplex [auto|half|full]
                     | auto | Enables automatic duplexity on an interface port. The port automatically detects whether it should run in full or half-duplex mode. (default setting) |
                     | half | Sets the port to half-duplex mode. Allows communication in one direction only at any given time. When selected, data is sent over the port, then immediately data is received from the direction in which the data was transmitted. |
                     | full | Sets the port to full-duplex mode. Allows communication in both directions simultaneously. When selected, the port can send data while receiving data as well. |
nx9500-6C8809(config-profile-testnx5500-if-ge1)#duplex full
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
 interface ge1
  description "This is GigabitEthernet interface for Royal King"
  duplex full
  dot1x supplicant username Bob password 0 test@123
  ip dhcp trust
  qos trust dscp
  qos trust 802.1p
  channel-group 1
Related Commands
                     | no | Reverts to default (auto) |
