A user-based VLAN is effective only if dynamic VLAN authorization is enabled for the WLAN.policy [access|day|inactivity-timeout|role|session-time|ssid|time|vlan]
policy vlan <1-4094>
policy access [all|console|ssh|telnet|web]
policy access [all|console|ssh|telnet|web] {(all|console|ssh|telnet|web)}
         policy day [all|fr|mo|sa|su|th|tu|we|weekdays] {(fr|mo|sa|su|th|tu|we|weekdays)}
         policy inactivity-timeout <60-86400>
policy role [device-provisioning-admin|helpdesk|monitor|network-admin|security-admin| superuser|system-admin|web-user-admin]
policy session-time <5-144000>
policy ssid <SSID>
policy time start <HH:MM> end <HH:MM>
Access and role settings are applicable only to a management group. They cannot be configured for a RADIUS non-management group.policy vlan <1-4094>
| vlan <1-4094> | Sets the guest RADIUS group‘s VLAN ID from 1 -
                        4094. The VLAN ID is representative of the shared SSID each group member
                        (user) employs to inter-operate within the network (once authenticated by
                        the local RADIUS server). This option applicable to a guest user group, which has guest access and temporary permissions to the local RADIUS server. The terms of the guest access can be set uniquely for each group. Guest user groups cannot be made management groups with unique access and role permissions. Note: Enable
                           dynamic VLAN assignment for the WLAN for the VLAN assignment to take
                           effect. |
         | access | Configures access type for a management group.
                           Management groups can be assigned unique access and role permissions.
 These parameters are recursive, and you can provide access to more than one component. |
| role [device-provisioning-admin|helpdesk|monitor|network-admin| security-admin|superuser|system-admin|web-user-admin] | Configures the role assigned to a management RADIUS
                           group. If a group is listed as a management group, it may also have a
                           unique role assigned. Available roles include:
| policy inactivity-timeout <60-86400> | Configures the inactivity time for this RADIUS
                        group users. If a frame is not received from a client for the specified
                        period, then the client‘s session is removed. When defined, this value is
                        used instead of the captive-portal inactivity timeout. If the inactivity
                        timeout is not configured in the radius-group context or the captive-portal
                        context, the default timeout (60 seconds) is applied.
| policy session-time <5-144000> | Configures the session duration for client‘s
                        belonging to a specific vendor group. Once configured, this is the duration
                        for which over-the-air, on-boarded, successfully authenticated devices,
                        belonging to a vendor group, get online access. The session is removed on
                        completion of this duration. The vendor‘s RADIUS group takes precedence over
                        statically configured group for device registration.
 Note: For more information, see configuring-device-registration-with-dynamic-vlan-assignment. |
policy ssid <SSID>
| ssid <SSID> | Sets the SSID (Service Set Identifier) for this guest RADIUS group. Use this
                        command to assign SSIDs that users within this RADIUS group are allowed to
                        associate. Assign SSIDs of those WLANs only that the guest users need to
                        access. This option is not available for a management group.
         | day [all|fr|mo|sa|su|th|tu|we|weekdays] {(fr|mo|sa|su|th|tu|we| weekdays)} | Configures the days on which this guest RADIUS
                        group members can access the local RADIUS resources. The options are
                        recursive, and you can provide access on multiple days.
| time start<HH:MM> end <HH:MM> | Configures the time when this RADIUS group can access the network
A management group access policy provides:
access details
user role
policy's start and end time
The SSID, day, and VLAN settings are not applicable to a management user group.
The following example shows a RADIUS guest group settings:
nx9500-6C8809(config-radius-group-test)#policy time start 13:30 end 17:30
         nx9500-6C8809(config-radius-group-test)#policy day all
         nx9500-6C8809(config-radius-group-test)#policy vlan 1
         nx9500-6C8809(config-radius-group-test)#policy ssid test
         nx9500-6C8809(config-radius-group-test)#show context radius-group test guest policy vlan 1 policy ssid test policy day mo policy day tu policy day we policy day th policy day fr policy day sa policy day su policy time start 13:30 end 17:30 nx9500-6C8809(config-radius-group-test)#
The following example shows a RADIUS management group settings:
nx9500-6C8809(config-radius-group-management)#policy access console ssh telnet
         nx9500-6C8809(config-radius-group-management)#policy role network-admin
         nx9500-6C8809(config-radius-group-management)#policy time start 9:30 end 20:30
         nx9500-6C8809(config-radius-group-management)#show context radius-group management policy time start 9:30 end 20:30 policy access console ssh telnet web policy role network-admin nx9500-6C8809(config-radius-group-management)#
| no | Removes or modifies a RADIUS group's access settings |
