net-auth-type
Configures the network authentication type used in this hotspot. The details configured are returned in response to an ANQP query. Use this option to specify how W-iFi connection attempts are authenticated and validated using a dedicated redirection URL resource.
Syntax
net-auth-type [accept-terms|dns-redirect|http-redirect|online-enroll] {url <URL>}
Parameters
net-auth-type
Specifies the network authentication type used with this passpoint policy. The options are: accept-terms, dns-redirect, http-redirect, and online-enroll.
accept-terms
Enables user acceptance of terms and conditions
dns-redirect
Enables DNS redirection of user
http-redirect
Enables HTTP redirection of user
online-enroll
Enables online user enrolment
url <URL>
Optional. Specify the location for each of above network authentication types.
nx9500-6C8809(config-passpoint-policy-test)#net-auth-type accept-terms url www.test.com
nx9500-6C8809(config-passpoint-policy-test)#show context
passpoint-policy test
 access-network-type chargeable-public
 connection-capability ip-protocol 2 port 10 closed
 nai-realm example
  eap-method 1 ttls auth-param vendor hex 00001E
  eap-method 2 rsa-public-key auth-param credential cert
 3gpp mcc 505 mnc 14
Related Commands
no
Removes the network authentication type configured with this passpoint policy
