The beacon format advertises how a mesh-capable access point acts. APs can act either as an access point or a meshpoint.
beacon-format [access-point|mesh-point]
| beacon-format | Configures how a mesh capable access point acts in a mesh network |
| access-point | Uses access point style beacons |
| mesh-point | Uses meshpoint style beacons (this is the default setting) |
nx9500-6C8809(config-meshpoint-test)#beacon-format access-point
         nx9500-6C8809(config-meshpoint-test)#show context meshpoint test meshid test beacon-format access-point control-vlan 1 allowed-vlans 1,10-16,18-23 security-mode none no root nx9500-6C8809(config-meshpoint-test)#
nx9500-6C8809(config-meshpoint-test)#no beacon-format
         nx9500-6C8809(config-meshpoint-test)#show context meshpoint test meshid test beacon-format mesh-point control-vlan 1 allowed-vlans 1,10-16,18-23 security-mode none no root nx9500-6C8809(config-meshpoint-test)#
| no (meshpoint-config) | Resets the beacon format for this meshpoint to its default (mesh-point) |
