AP505i Specifications
            AP505i is a next generation,
                enterprise-class 802.11ax access point. The “i” in AP505i indicates that it comes with
                internal antennas. The AP505i can be used in stadiums, public
                venues such as hospitals and hotels, retail industry, and educational institutions.
                The 802.11ax technology supports more users and internet of things
                (IoT) devices.
                - Radios: 2 radios (one band locked
                    at 2.4 GHz and the other band at 5 GHz); 1 IoT radio (2.4 GHz)
- Console port: RJ45
- Two Ethernet ports:
                        - GE1 - 10/100/1000/2500
                            Mbps auto-negotiation Ethernet port, RJ45, with PoE In
- GE2 - 10/100/1000 Mbps
                            auto-negotiation Ethernet port, RJ45, with NO PoE
- LEDs: 6 LEDs; all LEDs will be on
                    during reset
- One reset button
- Power: PoE 802.3at; 12VDC
                    external power in connector
- Antennas:
                        - Eight WiFi internal
                            antennas
- One BLE internal
                            antenna
For more information on
                the 802.11ax access points, refer to their respective
installation guides.
