Creates a user-defined role and enters its configuration mode. Each role consists of a set of filters and action. The filters are match criteria used to filter wireless clients. And the action defines the action taken when a client matches the specified filters.
user-role <ROLE-NAME> precedence <1-10000>
| user-role <ROLE-NAME> | Configures the user role name
| precedence <1-10000> | Sets the precedence for this role Note: Lower the precedence,
                           higher is the role priority. Precedence determines the order in which a
                           role is applied. If a wireless client matches multiple roles, the role
                           with the lower precedence is applied before those with higher precedence.
                           While there is no default precedence for a role, two or more roles can
                           share the same precedence. |
nx9500-6C8809(config-role-policy-test)#user-role testing precedence 10
         nx9500-6C8809(config-role-policy-test)#show context role-policy test user-role testing precedence 10 default-role use ip-access-list in test precedence 1 nx9500-6C8809(config-role-policy-test)#
nx9500-6C8809(config-role-policy-test-user-role-testing)#? Role Mode commands: ap-location AP Location configuration assign Assign parameters to the role authentication-type Type of Authentication captive-portal Captive-portal based Role Filter city City configuration client-identity Client identity company Company configuration country Country configuration department Department configuration emailid Emailid configuration employee-type Employee-type configuration employeeid Employeeid configuration encryption-type Type of encryption group Group configuration memberOf MemberOf configuration mu-mac MU MAC address configuration no Negate a command or set its defaults radius-user Radius-user configuration ssid SSID configuration state State configuration title Title configuration use Set setting to use user-defined User-defined configuration clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-role-policy-test-user-role-testing)#
| no (role-policy-config-mode-command) | Removes an existing user role from the role policy |
