ap-detection
      Enables the detection of unauthorized or unsanctioned APs.
         Unauthorized APs are untrusted access points connected to an access point managed network.
         These untrusted APs accept wireless client associations. It is important to detect such
         rogue APs and declare them unauthorized. Rogue AP detection is disabled by
         default.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         ap-detection {ageout|air-termination|interferer-threshold|recurring-event-interval|wait-time}
         ap-detection {ageout <30-86400>|interferer-threshold <-100--10>|recurring-event-interval <0-10000>|
wait-time <10-600>}
         ap-detection air-termination {allow-channel-switch|mode [auto|manual]}
      Parameters
wait-time <10-600>}
                     | ap-detection | Enables detection of unauthorized or unsanctioned
                        APs |
                     | ageout <30-86400> | Optional. Configures the unauthorized AP ageout
                        interval. The WIPS policy uses this value to ageout unauthorized APs.
                           <30-86400> – Sets an ageout interval from 30 -
                              86400 seconds. The default is 5 minutes (300 seconds). |
                     | recurring-event-interval <0-10000> | Configures recurring event interval help of
                        unauthorized APs
                           <0-10000> – Configures the recurring interval
                              between 0 - 10000 seconds. The default is 300 seconds. |
                     | interferer-threshold <-100--10> | Configures RSSI threshold value to determine if
                        an unsanctioned ap is an interferer or not
                           <-100--10> – Configures the rssi threshold between -100 - -10 dBm.
                              The default is -75 dBm. |
                     | wait-time <10-600> | Optional. Configures the wait time before a
                        detected AP is declared as unauthorized and potentially removed
                           <10-600> – Sets a wait time from 10 - 600 seconds. The default is
                              1 minute (60 seconds). |
                     | ap-detection | Enables detection of unauthorized or unsanctioned APs |
                     | air-termination {allow-channel-switch| mode [auto|manual]} | Enables air termination of unauthorized APs. This option is disabled by
                           default.
                           allow-channel-switch – Optional. Allows channel switch of
                              unauthorized APs based on the channel mode. This option is disabled by
                              default.mode [auto|manual] – Optional. Select the mode as
                                 auto or manual to configure. The
                              default setting is manual. |
         nx9500-6C8809(config-wips-policy-test)#ap-detection wait-time 15
         nx9500-6C8809(config-wips-policy-test)#ap-detection age-out 50
         nx9500-6C8809(config-wips-policy-test)#show context
wips-policy test
 ap-detection-age-out 50
 ap-detection-wait-time 15
         nx9500-6C8809(config-wips-policy-test2)#ap-detection recurring-event-interval 10
         nx9500-6C8809(config-wips-policy-test2)#show context
wips-policy test2
