application
    Creates a new
      application definition and enters its configuration mode. Use this command
      to create a customized application detection definition.
The WiNG 7.1.X release
        does not support DPI (application visibility) on AP5XX model access
        points.
Supported on the following
        platforms:
                - Access Points — AP6522, AP6562,
                    AP7161, AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP763, AP7662,
                    AP8163, AP8543, AP8533
- Service Platforms —
- Virtual Platforms — CX9000,
Syntax
      application <APPLICATION-NAME>
    Parameters
              | application <APPLICATION-NAME> | Creates a new application definition and enters its
                configuration mode
                  <APPLICATION-NAME> – Specify a name of the new application definition. It
                    is created if not already existing in the system. |
      nx9500-6C8809(config)#application Bing
nx9500-6C8809(config-application-Bing)#?
Application Mode commands:
  app-category  Set application category (default is custom)
  description   Add application description
  https         Secure HTTP
  no            Negate a command or set its defaults
  use           Set setting to use
  clrscr        Clears the display screen
  commit        Commit all changes made in this session
  do            Run commands from Exec mode
  end           End current mode and change to EXEC mode
  exit          End current mode and down to previous mode
  help          Description of the interactive help system
  revert        Revert changes
  service       Service Commands
  show          Show running system information
  write         Write running configuration to memory or terminal
    Related Commands
              | no | Removes an existing application definition |
