aaa-login [local|radius|tacacs]
aaa-login local
aaa-login radius [external|fallback|fallthrough|policy <AAA-POLICY-NAME>]
         aaa-login tacacs [accounting|authentication|authorization {fallback}|fallback|
fallthrough|policy <AAA-TACACS-POLICY-NAME>]
      aaa-login local
| local | Sets local as the preferred authentication mode. Local authentication
                        uses the local username/password database to authenticate a user. Note: By default the local
                           authentication mode is enabled.  |
         | radius | Enables external RADIUS server authentication as the primary authentication mode. If enabling external RADIUS server authentication, configure one of the following options: external, fallback, or fallthrough. |
| external | Enables external RADIUS server as the primary authentication mode. When configured, client authentication requests are forwarded to an external RADIUS server. However, this option does not provide fallback to local database authentication in case the server is unreachable or if the server rejects the authentication request. |
| fallback | Configure this option to revert to local database authentication in case
                        the external RADIUS server is unreachable. When this option is enabled, RADIUS authentication is attempted first. However, if the external RADIUS server is unreachable the local database is used to authenticate the user. |
| fallthrough | Configure this option to revert to local database
                        authentication in the following scenarios:
 When this option is enabled, RADIUS authentication is attempted first. However, if the external RADIUS server is unreachable or rejects the authentication request the local database is used to authenticate the user. |
| policy <AAA-POLICY-NAME> | Associates a AAA policy with this management policy. If enabling external RADIUS server authentication, associate a AAA policy. Controllers, service platforms and access points not using their local RADIUS resource will need to inter-operate with a RADIUS and LDAP Server (AAA Servers) to provide a user database containing user authentication data. The AAA policy points to this external RADIUS server resource.
 Note: For more
                           information on configuring AAA policy, see AAA Policy. |
aaa-login tacacs [accounting|authentication|authorization|fallback|fallthrough|
         | tacacs | Enables external Terminal Access Control Access-Control System (TACACS) server authentication. If enabling external TACACS server authentication, configure the following parameters: accounting, authentication, authorization, fallback, or fallthrough. |
| accounting | Configure to enable TACACS accounting on login. |
| authentication | Configure to enable TACACS authentication on login. |
| authorization {fallback} | Configure to enable TACACS authorization on login.
| fallback | Select this option to revert to local database authentication in case
                        the external TACACS server is unreachable. When this option is enabled, TACACS authentication is attempted first. However, if the external TACACS server is unreachable the local database is used to authenticate the user. |
| fallthrough | Select this option to revert to local database
 When this option is enabled, TACACS authentication is attempted first. However, if the external TACACS server is unreachable or rejects the authentication request the local database is used to authenticate the user. |
| policy <AAA-TACACS-POLICY- NAME> | Associates a AAA TACACS policy with this management policy. If enabling external TACACS server authentication, associate a AAA TACACS policy. The AAA TACACS policy points to the external TACACS server resource.
 Note: For more
                           information on configuring AAA TACACS policy, see AAA-TACACS Policy. |
Use AAA login to determine whether management user authentication must be performed against a local user database or an external RADIUS server.
nx9500-6C8809(config-management-policy-test)#aaa-login radius policy test
nx9500-6C8809(config-management-policy-test)#show context management-policy test http server no ssh aaa-login radius policy test nx9500-6C8809(config-management-policy-test)#
| no | Removes the TACACS server policy settings |
