no [aaa-login|allowed-locations|banner|ftp|http|https|idle-session-timeout|ipv6|passwd-entry| privilege-mode-password|rest-server|restrict-access|snmp-server|ssh|t5|telnet|user|service]
no aaa-login tacacs [accounting|authentication|authorization|fallback|policy]
no allowed-location <LOCATION-TAG>
no banner motd
no ftp {password|rootdir}
         no http server
no https [server|sslv3|use-secure-ciphers-only]
no passwd-entry role [device-provisioning-admin|helpdesk|monitor|network-admin|security-admin| superuser|system-admin|vendor-admin|web-user-admin]
no [idle-session-timeout|privilege-mode-password|rest-server|restrict-access]
no ipv6 restrict-access
no snmp-server [community|display-vlan-info-per-radio|enable|host|manager|max-pending-requests| request-timeout|suppress-security-configuration-level|throttle|user]
no snmp-server [community <WORD>|display-vlan-info-per-radio|enable traps|host <IP> {<1-65535>}|
manager [all|v1|v2|v3]|max-pending-requests|request-timeout|suppress-security-configuration-level|
throttle|user [snmpmanager|snmpoperator|snmptrap]]
         no ssh {login-grace-time|port|use-key}
         no t5 snmp-server [community|enable|host]
no [telnet|user <USERNAME>]
no service prompt crash-info
no <PARAMETERS>
| no <PARAMETERS> | Removes or reverts this Management policy settings based on the parameters passed |
The following example shows the management policy ‘test' settings before the ‘no' commands are executed:
nx9500-6C8809(config-management-policy-test)#show context management-policy test http server https server ftp username superuser password 1 7ccb4568cb83e54f1e402f785a78ee930a453afda152baaf7c2b79277f225872 rootdir dir no ssh aaa-login radius external aaa-login radius policy test idle-session-timeout 100 banner motd "Have a Good Day" nx9500-6C8809(config-management-policy-test)#
nx9500-6C8809(config-management-policy-test)#no banner motd
nx9500-6C8809(config-management-policy-test)#no idle-session-timeout
nx9500-6C8809(config-management-policy-test)#no http server
The following example shows the management policy ‘test‘ settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-management-policy-test)#show context management-policy test no http server https server ftp username superuser password 1 626b4033263d6d2ae4e79c48cdfcccb60fd4c77a8da9e365060597a6d6570ec2 rootdir dir no ssh aaa-login radius external aaa-login radius policy test idle-session-timeout 0 nx9500-6C8809(config-management-policy-test)#
