use
      interface-config-ge-instance
Specifies the IP (IPv4 and IPv6) access list and MAC access list used with this Ethernet port. The associated ACL firewall inspects IP and MAC traffic flows and detects attacks typically not visible to traditional wired firewall appliances.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
use [ip-access-list in <IPv4-ACCESS-LIST-NAME>|ipv6-access-list <IPv6-ACCESS-LIST-NAME>|
mac-access-list in <MAC-ACCESS-LIST-NAME>]
      Parameters
                     | ip-access-list
                        in <IPv4-ACCESS-LIST-NAME> | Associates an
                        IPv4 access list with this Ethernet port. IPv4 is a connectionless protocol
                        for packet switched networking. IPv4 operates as a best effort delivery
                        method, as it does not guarantee delivery, and does not ensure proper
                        sequencing or duplicate delivery (unlike (TCP). IPv4 hosts can use link
                        local addressing to provide local connectivity.
                           in – Applies the IPv4 ACL
                              on incoming packets
                                 <IPv4-ACCESS-LIST-NAME> – Specify the IPv4 access list
                                    name (it should be an existing and configured). |
                     | ipv6-access-list
                        in <IPv6-ACCESS-LIST-NAME> | Associates an
                        IPv6 access list with this Ethernet port. IPv6 is the latest revision of the
                        IP designed to replace IPv4. IPV6 provides enhanced identification and
                        location information for computers on networks routing traffic across the
                        Internet. IPv6 addresses are composed of eight groups of four hexadecimal
                        digits separated by colons.
                           in – Applies the IPv6 ACL
                              on incoming packets
                                 <IPv6-ACCESS-LIST-NAME> – Specify the IPv6 access list
                     | mac-access-list
                        in <MAC-ACCESS-LIST-NAME> | Associates a MAC
                        access list with this Ethernet port. MAC ACLs filter/mark packets based on
                        the MAC address from which they arrive, as opposed to filtering packets on
                        layer 2 ports.
                           in – Applies the MAC ACL
                              on incoming packets
                                 <MAC-ACCESS-LIST-NAME> – Specify the MAC access list name
nx9500-6C8809(config-profile-testnx5500-if-ge1)#use mac-access-list in test
nx9500-6C8809(config-profile-testnx5500-if-ge1)#use ip-access-list in test
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
 interface ge1
  description "This is GigabitEthernet interface for Royal King"
  speed 10
  duplex full
  switchport mode accessi
  switchport access vlan 1
  spanning-tree bpduguard enable
  spanning-tree bpdufilter disable
  spanning-tree force-version 1
--More--
Related Commands
                     | no | Disassociates the IP access list or MAC access list from the interface |
