no [alias|channel-list|contact|control-vlan|controller-managed|country-code|geo-coordinates|layout|location|location-server|location-tenantid|mac-name|nsight-sensor|override-smartrf|override-wlan|sensor-server|stats|timezone|tree-node|use]
no [channel-list [2.4GHz|5GHz|dynamic]|contact|control-vlan|controller-managed|country-code|location|location-server 1|location-tenantid|mac-name <MAC>|nsight-sensor|sensor-server <1-3>|stats update-interval|timezone|tree-node]
no alias [address-range|host|network|network-group [address-range|host|network]|network-service|number|string|vlan] <ALIAS-NAME>
no layout {(area <AREA-NAME>|floor <FLOOR-NAME>)}
         no override-smartrf channel-list [2.4GHz|5GHz]
no override-wlan <WLAN-NAME> [shutdown|ssid|template|vlan-pool [<1-4094>|all]|wep128 [key <1-3>|transmit-key]|wpa-wpa2-psk]
no use [ble-data-export-policy|database-policy|license|nsight-policy|rtl-server-policy|sensor-policy|smart-rf-policy|wips-policy]
      no <PARAMETERS>
| no <PARAMETERS> | Removes or reverts this RF Domain‘s settings based on the parameters passed |
The following example shows the default RF Domain settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-rf-domain-default)#show context rf-domain default location SanJose contact Bob+14082778691 country-code us channel-list 2.4GHz 1,2,3,4,5,6,7,8,9,10 mac-name 11-22-33-44-55-66 TestDevice layout area Ecospace floor Floor1 map-location www.firstfloor.com units meters control-vlan 1 nx9500-6C8809(config-rf-domain-default)#
nx9500-6C8809(config-rf-domain-default)#no channel-list 2.4GHz 1-10
         nx9500-6C8809(config-rf-domain-default)#no mac-name 11-22-33-44-55-66
         nx9500-6C8809(config-rf-domain-default)#no location
         nx9500-6C8809(config-rf-domain-default)#no control-vlan
         The following example shows the default RF Domain settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-rf-domain-default)#show context rf-domain default contact Bob+14082778691 country-code us layout area Ecospace floor Floor1 map-location www.firstfloor.com units meters nx9500-6C8809(config-rf-domain-default)#
