force (meshpoint-config)
      Forces formation of sub-optimal paths through the meshpoint‘s root node.
        As per legacy behavior, non-root devices under the same root, communicated by forming direct
        paths through the network. This option allows non-root devices, within the meshpoint, to
        communicate by forming paths through the root node.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      force [peer-paths-through-root|peer-paths-with-root]
    Parameters
              | force | Forces formation of sub-optimal paths through the
                meshpoint root node. |
              | peer-paths-through-root | Forces non-root devices to communicate by forming
                sub-optimal paths through the root node. This option is disabled by default. |
              | peer-paths-with-root | Forces non-root devices to communicate by forming
                sub-optimal paths with the root node. Does not allow formation of ad-hoc
                peer-to-peer paths. This option is disabled by default. |
      nx9500-6C8809(config-meshpoint-test)#force peer-paths-through-root
      nx9500-6C8809(config-meshpoint-test)#show context
meshpoint test
 meshid test
 beacon-format mesh-point
 control-vlan 25
 security-mode none
 no root
