client-load-balancing
      Enforces client load balancing on a
         WLAN‘s access point radios. When enforced, probe and association requests are not responded
         to, forcing a client to associate with another access point radio. This feature is disabled
         by default.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         client-load-balancing {allow-single-band-clients|band-discovery-intvl|
capability-ageout-time|max-probe-req|probe-req-invl}
         client-load-balancing {allow-single-band-clients [2.4ghz|5ghz]|
band-discovery-intvl <0-10000>|capability-ageout-time <0-10000>}
         client-load-balancing {max-probe-req|probe-req-intvl} [2.4ghz|5ghz] <0-10000>
      Parameters
                     | client-load-balancing | Configures client load balancing on a WLAN |
                     | allow-single-band-clients [2.4GHz|5GHz] | Optional. Allows single band clients to associate even during load
                           balancing
                           2.4GHz – Enables load
                              balancing across 2.4 GHz channels5GHz – Enables load
                              balancing across 5.0 GHz channels This option is enabled by default for 2.4 and 5.0 GHz
                        bands. |
                     | band-discovery-intvl <0-10000> | Optional. Configures time interval to discover a client's band
                        capability before connection
                           <0-10000> –
                              Specify a value from 0 - 10000 seconds. The default is 10
                              seconds. |
                     | capability-ageout-time <0-10000> | Optional. Configures a client's capability ageout interval. This is the
                        time for which a client‘s capabilities are retained in the device‘s internal
                        table. Once this time is exceeded the client‘s capabilities are aged out.
                           <0-10000> –
                              Specify a value from 0 - 10000 seconds. The default is 3600
                              seconds. |
         client-load-balancing {max-probe-req|probe-req-intvl} [2.4Ghz|5Ghz] <0-10000>
                     | client-load-balancing | Configures WLAN client load balancing |
                     | max-probe-req [2.4GHz|5GHz] <0-10000> | Optional. Configures the maximum client probe requests allowed for 2.4
                        GHz and 5.0 GHz bands
                           2.4GHz – Configures
                              maximum client probe requests on 2.4 GHz radios5GHz – Configures
                              maximum client probe requests on 5.0 GHz radios
                                 <0-10000>
                                    – Specify a client probe request threshold from 0 - 10000. The
                                    default for both 2.4 and 5.0 GHz radios is 60. |
                     | probe-req-intvl 2.4GHz|5GHz] <0-10000> | Optional. Configures client probe request interval limits for device
                           association
                           2.4GHz – Configures
                              the client probe request interval on 2.4 GHz radios5GHz – Configures the
                              client probe request interval on 5.0 GHz radios
                                 <0-10000>
                                    – Specify a value from 0 - 10000. The default for both 2.4 and
                                    5.0 GHz radios is 10 seconds. |
         nx9500-6C8809(config-wlan-test)#client-load-balancing band-discovery-intvl 2
         nx9500-6C8809(config-wlan-test)#client-load-balancing probe-req-intvl 5ghz 5
         nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode local
 encryption-type none
 authentication-type eap
 accounting syslog host 172.16.10.4 port 2
 captive-portal-enforcement fall-back
 acl exceed-rate wireless-client-denied-traffic 20 disassociate
 broadcast-dhcp validate-offer
