wpa2 (meshpoint-config)
      Use this command to configure the parameters of
         authentication mode specified using the ‘security-mode‘ keyword. This command also allows
         you to set a unicast and broadcast key rotation interval.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         wpa2 [eap|psk|key-rotation]
         wpa2 key-rotation [broadcast|unicast] <30-86400>
         wpa2 psk [0 <SECRET>|2 <SECRET>|<SECRET>]
         wpa2 eap [auth-type|identity|peap-mschapv2|tls]
         wpa2 eap [auth-type [peap-mschapv2|tls]|identity <WORD>]
         wpa2 eap peap-mschapv2 user <USER-NAME> password [0 <WORD>|2 <WORD>|<WORD>]
{trustpoint <TRUSTPOINT-NAME>}
         wpa2 eap tls trustpoint <TRUSTPOINT-NAME>
      Parameters
                     | wpa2 key-rotation | Enables periodic rotation of encryption keys used for broadcast and
                        unicast traffic |
                     | broadcast | Configures key rotation interval for broadcast and multicast traffic.
                        This option is disabled by default. When enabled, the key indices used
                           for encrypting/decrypting broadcast traffic is alternatively rotated
                           based on the defined interval. Key rotation enhances the broadcast
                           traffic security on the WLAN. |
                     | unicast | Configures key rotation interval for unicast traffic. This option is
                        disabled by default. |
                     | <30-86400> | Configures key rotation interval from 30 - 86400 seconds for unicast or
                        broadcast transmission |
                     | wpa2 psk | Configures the shared key for authentication mode
                        PSK. If the security mode is set as ‘psk‘ using the ‘security-mode‘ keyword,
                        use this command to configure the pre-shared key. |
                     | secret [0 <SECRET>| 2
                        <SECRET>|<SECRET>] | Configures the PSK used to authenticate this
                        meshpoint with other meshpoints in the network |
                     | wpa2 eap | Configures the 802.1X/EAP based authentication type for this meshpoint.
                        If the security mode is set as ‘eap‘ using the ‘security-mode‘ keyword, use
                        this command to specify the EAP type. The options are: peap-mschapv2 and
                        tls. |
                     | auth-type [peap-mschapv2|tls] | Specifies the EAP authentication type. The options are:
                           peap-mschapv2 – Configures EAP authentication type as PEAP
                                 (Protected Extensible Authentication Protocol) with
                              default auth type MSCHAPv2. This is the default setting. If using
                                 auth-type as ‘peap-mschapv2‘, use the ‘peap-mschapv2‘ keyword to
                                 configure user credentials and trustpoint details. tls – Configures EAP authentication type as TLS (Transport
                                 Layer Security) If using auth-type as ‘tls‘, use the
                                 ‘tls‘ keyword to configure trustpoint details.  Note: The certificate should be issued from an Enterprise or public
                           certificate authority to allow 802.1X clients to validate the identity of
                           the authentication server prior to forwarding credentials. |
                     | identity <WORD> | Configures identity to be used during phase1 authentication
                           <WORD> – Enter a string up to 256 characters in length (this
                              should not be actual identity of user but some anonymous/bogus
                              username). |
                     | wpa2 eap peap-mschapv2 | Configures PEAP-related user credentials and
                        trustpoint details |
                        <WORD>|<WORD>] | Specify the user credentials used for
                           authentication
                            user <USER-NAME> – Specify the user
                              name password [0 <WORD>|2
                              <WORD>|<WORD>] – Specify the password associated with the
                              specified user. |
                     | trustpoint <TRUSTPOINT-NAME> | Optional. Associates a trustpoint used for
                        installing CA certificate and verifying server certificate
                            <TRUSTPOINT-NAME> – Specify the trustpoint
                              name (should be existing and configured). |
                     | wpa2 eap tls | Configures TLS client related parameters |
                     | trustpoint <TRUSTPOINT-NAME> | Configures trustpoint details trustpoint
                           <TRUSTPOINT-NAME> – Assigns a trustpoint to be used for installing
                              TLS client certificate, client private key, and CA certificate <TRUSTPOINT-NAME> – Specify the trustpoint name (should be
                              existing and configured) |
         nx9500-6C8809(config-meshpoint-test)#wpa2 key-rotation broadcast 600
         nx9500-6C8809(config-meshpoint-test)#wpa2 key-rotation unicast 1200
         nx9500-6C8809(config-meshpoint-test)#wpa2 psk Test Company
         nx9500-6C8809(config-meshpoint-test)#show context
meshpoint test
 description "This is an example of a meshpoint description"
 meshid TestingMeshPoint
 shutdown
 beacon-format mesh-point
 control-vlan 1
 allowed-vlans 1,10-16,18-23
 neighbor inactivity-timeout 300
 data-rates 2.4GHz bgn
 data-rates 5GHz an
 security-mode psk
 wpa2 psk 0 Test Company
 root
         The following example shows root meshpoint configuration with EAP authentication
            enabled:
nx9500-6C8809(config-meshpoint-root)#show context
meshpoint root
 meshid test
 control-vlan 101
 allowed-vlans 101,103
 use aaa-policy test
 security-mode eap
 root
The following example shows non-root meshpoint configuration with EAP PEAP-MSCHAPv2
            authentication:
nx9500-6C8809(config-meshpoint-testNoRoot)#show context
meshpoint testNoRoot
 meshid test
 control-vlan 101
 security-mode eap
 wpa2 eap peap-mschapv2 user tester123 password 0 testing1234 trustpoint mesh1
 wpa2 eap identity tester123
 no root
The following example shows non-root meshpoint configuration with EAP TLS
            authentication:
 meshid test
 control-vlan 101
 security-mode eap
 wpa2 eap tls trustpoint mesh1
 no root
