Configures the L2TPv3 tunnel‘s peers. At least one peer must be specified.
peer <1-2> {hostname|ip-address|ipsec-secure|router-id|udp}
         peer <1-2> {hostname [<HOSTNAME>|any]} {ipsec-secure|router-id|udp}
         peer <1-2> {ip-address <IP>} {hostname|ipsec-secure|router-id|udp}
         peer <1-2> {ipsec-secure} {gw [<IP>|<WORD>]}
         peer <1-2> {router-id [<IP>|<WORD>|any]} {ipsec-secure|udp}
         peer <1-2> {udp} {ipsec-secure|port <1-65535>}
         | peer <1-2> | Configures the tunnel‘s peer ID
 Note: At any time the tunnel is established with only
                           one peer, unless fast-failover support is configured on the L2TPv3
                           tunnel. For more information, see fast-failover. |
| hostname [<HOSTNAME>|any] | Optional. Configures the peers‘ hostname. The hostname options are:
| ipsec-secure {gw [<IP>|<WORD>]} | After specifying the peer hostname, optionally specify the IPSec settings:
| router-id [<IP>|<WORD>|any] | After specifying the peer hostname, optionally specify router ID settings:
| udp {ipsec-secure gw|port <1-65535> {ipsec-secure}} | After specifying the peer hostname, optionally specify UDP settings: The UDP option configures the encapsulation mode for this tunnel.
         | peer <1-2> | Configures the tunnel‘s peer ID from 1 - 2. At any time the tunnel is established with only one peer. |
| ip-address <IP> | Optional. Configures the peer‘s IP address in the
                           A.B.C.D format
| hostname [<FQDN>|any] | After specifying the peer IP address, optionally specify the peer‘s hostname: Optional. Configures the peers‘ hostname. The hostname options are:
| ipsec-secure {gw [<IP>|<WORD>]} | After specifying the peer IP address, optionally specify the IPSec settings:
| router-id [<A.B.C.D>|<WORD>| any] | After specifying the peer IP address, optionally specify the router ID using one of the following options:
| udp {ipsec-secure gw|port <1-65535> {ipsec-secure}} | After specifying the peer IP address, optionally specify the peer‘s UDP port settings: The UDP option configures the encapsulation mode for this tunnel.
| ipsec-secure {gw [<IP>|<WORD>]} | Optional. Enables auto IPSec for this peer
         | peer <1-2> | Configures the tunnel peer ID from 1 - 2. At any time the tunnel is established with only one peer. |
| router-id [<A.B.C.D>|<WORD>| any] | Optional. Configures the peer‘s router-id in one of the following formats:
| ipsec-secure {gw [<IP>|<WORD>]} | After specifying the peer‘s router ID, optionally specify the IPSec settings.
| udp {ipsec-secure gw| port <1-65535> {ipsec-secure}} | After specifying the peer‘s router ID, optionally specify the IPSec settings. The UDP option configures the encapsulation mode for this tunnel.
| udp {ipsec-secure| port <1-65535> {ipsec-secure}} | Optional. Configures UDP encapsulation for this tunnel‘s pee (default encapsulation is IP)
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#peer 2 hostname tunnel1peer1 udp port 100
         nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1))#show context l2tpv3 tunnel Tunnel1 peer 2 hostname tunnel1peer1 udp port 100 establishment-criteria cluster-master nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#
| no | Removes the peer configured for this tunnel |
