ldap-agent
      Displays an LDAP agent‘s join status
         (join status to a LDAP server domain). Use this command When LDAP is specified the external
         resource (as opposed to local RADIUS resources) to validate PEAP-MS-CHAP v2 authentication
         requests, user credentials, and password information needs to be made available locally to
         successfully connect to the external LDAP server. Up to two LDAP Agents (primary and
         secondary external resources) can be defined as external resources for PEAP-MS-CHAP v2
         authentication requests.
This command
            is not available in USER EXECUTABLE ,mode
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         show ldap-agent join-status {on <DEVICE-NAME>}
      Parameters
                     | ldap-agent | Displays LDAP agent related configuration |
                     | join-status | Displays if the LDAP agent has successfully joined a LDAP server‘s
                        domain |
                     | on <DEVICE-NAME> | Optional. Displays if the LDAP agent has successfully joined a specified
                        LDAP server‘s domain.
                           <DEVICE-NAME> –
                              Specify the name of the device running the LDAP server (access point,
                              wireless controller, or service platform). |
         nx9500-6C8809#show ldap-agent join-status
Primary LDAP Server's agent join-status : Joined domain TEST.
Secondary LDAP Server's agent join-status : Not Configured
nx9500-6C8809#
