dhcp-match-message-type
         Configures the DHCP message type to match
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         dhcp-match-message-type [all|any|discover|request]
      Parameters
                     | dhcp-match-message-type [all|any|discover|request] | Specifies the DHCP message type to consider for
                           matching
                              all – Matches all message types: discover and
                                 request. Indicates that the fingerprint is checked with both the
                                 DHCP request and the DHCP discover message.
                              any – Matches any message type: discover or
                                 request. Indicates that the fingerprint is checked with either the
                                 DHCP request or the DHCP discover message.
                              discover – Matches discover messages only. A
                                 match is made only if the discover message sent by the client
                                 matches the match criteria set in the client identity. Values
                                 configured for request messages are ignored.
                              request – Matches request messages only. A match
                                 is made only if the request message sent by the client matches the
                                 match criteria set in the client identity. Values configured for
                                 discover messages are ignored. |
         nx9500-6C8809(config-client-identity-test)#dhcp-match-message-type all
         nx9500-6C8809(config-client-identity-test)#show context
client-identity test
 dhcp 2 message-type discover option 2 exact hexstring 012456c22c44
 dhcp 1 message-type request option 60 exact ascii MSFT5.0
      Related Commands
                           no
                         | Removes the DHCP message type to match |
