interface-config-radio-instance
Configures the radio‘s mode of operation as radio share. A radio operating in the radio share mode services clients and also performs sensor functions (defined by the radio‘s ADSP licenses and profiles).
The sensor capabilities of the radio are restricted to the channel and WLANs defined on the radio.radio-share-mode [inline|off|promiscuous]
| radio-share-mode | Enables sharing of packets, switched by this radio, with the WIPS sensor module. There are two radio-share modes, these are: inline and promiscuous |
| inline | Enables sharing of all WLAN packets (matching the BSSID of the radio) serviced by the radio with the WIPS sensor module. |
| off | Disables radio share (no packets shared with the WIPS sensor module) |
| promiscuous | Enables the promiscuous radio share mode. In this mode the radio is configured to receive all packets on the channel irrespective of whether the destination address is the radio or not, and shares these packets with the WIPS sensor module for analysis (i.e. without filtering based on BSSI). |
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#radio-share-mode promiscuous nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 power 12 data-rates b-only placement outdoor mesh client off-channel-scan channel-list 2.4GHz 1 preamble-short guard-interval long ......................................................... non-unicast queue bss 16 50 antenna-diversity max-clients 100 radio-share-mode promiscuous airtime-fairness prefer-ht weight 6 lock-rf-mode extended-range 15 antenna-downtilt nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
| no (radio-interface-config-command) | Resets the radio share mode for this radio to its default |
