spanning-tree
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
spanning-tree [bpdufilter|bpduguard|force-version|guard|link-type|mst|
port-cisco-interoperability|portfast]
spanning-tree [force-version <0-3>|guard root|portfast]
spanning-tree [bpdufilter|bpduguard] [default|disable|enable]
spanning-tree link-type [point-to-point|shared]
spanning-tree mst <0-15> [cost <1-200000000>|port-priority <0-240>]
spanning-tree port-cisco-interoperability [disable|enable]
Parameters
force-version
<0-3> |
Specifies the
spanning tree force version. A version identifier of less than 2 enforces
the spanning tree protocol. Select one of the following versions:
- 0 – Spanning Tree Protocol
(STP)
- 1 – Not supported
- 2 – Rapid Spanning tree
Protocol (RSTP)
- 3 – Multiple Spanning Tree
Protocol (MSTP). This is the default setting
guard
root |
Enables Root
Guard for the port The Root
Guard disables superior BPDU (Bridge Protocol Data Unit)
reception. The Root Guard ensures the enabled port is a designated port.
If the Root Guard enabled port receives a superior BPDU, it moves to a
discarding state (root-inconsistent STP state). This state is equivalent
to a listening state, and data is not forwarded across the port.
Therefore, enabling the guard root enforces the root bridge position. Use
the no parameter with this command to disable the Root Guard.
portfast |
Enables rapid
transitions. Enabling PortFast allows the port to bypass the listening and
learning states. |
bpdufilter
[default|disable| enable] |
Sets a PortFast
BPDU filter for the port Use
the no parameter with this command to revert the port BPDU filter to its
default. The spanning tree protocol sends BPDUs from all ports. Enabling
the BPDU filter ensures PortFast enabled ports do not transmit or receive
BPDUs.
bpduguard
Enables BPDU
guard on a port Use the no
parameter with this command to set BPDU guard to its default.
When the BPDU guard is set for
a bridge, all PortFast-enabled ports that have the BPDU guard set to
default shut down upon receiving a BPDU. If this occurs, the BPDU is not
processed. The port can be brought back either manually (using the no
shutdown command), or by configuring the errdisable-timeout to enable the
port after a specified interval.
link-type
[point-to-point|shared] |
Enables
point-to-point or shared link types
- point-to-point – Enables
rapid transition. This option indicates the port should be treated as
connected to a point-to-point link. A port connected to a controller
is a point-to-point link.
- shared – Disables rapid
transition. This option indicates this port should be treated as
having a shared connection. A port connected to a hub is on a shared
link,
mst
<0-15> |
Configures MST
on a spanning tree |
cost
<1-200000000> |
Defines path
cost for a port from 1 - 200000000. The default path cost depends on the
speed of the port. The cost helps determine the role of the port in the MSTP
network. The designated cost is the cost for a packet to travel from this
port to the root in the MSTP configuration. The slower the media, the higher
the cost. |
port-priority
<0-240> |
Defines port
priority for a bridge from 1 - 240. Lower the priority greater is the
likelihood of the port becoming a designated port. Applying a higher value
impacts the port's likelihood of becoming a designated port. |
port-cisco-interoperability |
Enables
interoperability with Cisco's version of MSTP (which is incompatible with
standard MSTP) |
enable |
Enables CISCO
Interoperability |
disable |
Disables CISCO
Interoperability. The default is disabled. |
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree bpdufilter disable
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree bpduguard enable
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree force-version 1
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree guard root
nx9500-6C8809(config-profile-testnx5500-if-ge1)#spanning-tree mst 2 port-priority 10
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
interface ge1
description "This is GigabitEthernet interface for Royal King"
duplex full
--More--
Related Commands
no |
Removes spanning tree settings configured on this interface |
