telnet
      Enables Telnet. Telnet provides a
         command line interface to a remote host over TCP. Telnet provides no encryption, but it
         does provide a measure of authentication. Telnet access is disabled by default.By
            default Telnet, when enabled, uses Transmission Control Protocol (TCP) port
            23. Use this command to change the TCP port.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         telnet {port <1-65535>}
      Parameters
                     | telnet | Enables Telnet |
                     | port <1-65535> | Optional. Configures the Telnet port. This is the port used for Telnet
                           connections.
                           <1-65535> – Sets
                              a value from 1 - 165535. The default port is 23. |
         nx9500-6C8809(config-management-policy-test)#telnet port 200
         nx9500-6C8809(config-management-policy-test)#show context
management-policy test
 telnet port 200
 no http server
 https server
 ftp username superuser password 1 626b4033263d6d2ae4e79c48cdfcccb60fd4c77a8da9e365060597a6d6570ec2 rootdir dir
 ssh port 162
 snmp-server community snmp1 ro
 snmp-server user snmpmanager v3 encrypted des auth md5 0 test123
 snmp-server host 172.16.10.23 v3 162
 aaa-login radius external
 aaa-login radius policy test
 idle-session-timeout 0
 restrict-access host 172.16.10.2 log all
