By default, SSH is enabled from the factory settings on the controller. The controller requires an IP address and login credentials.
To enable SSH access on a device, login through the serial console and perform the following:
ap505-13403B>en ap505-13403B#
ap505-13403B#configure terminal Enter configuration commands, one per line. End with CNTL/Z. ap505-13403B(config)#
ap505-13403B(config)#management-policy ?
  MANAGEMENT  Name of the management policy to be configured (will be created
              if it does not exist)
ap505-13403B(config)#management-policy default
ap505-13403B(config-management-policy-default)#
                ap505-13403B(config-management-policy-default)#ssh ap505-13403B(config-management-policy-default)#commit write ap505-13403B(config-management-policy-default)#end ap505-13403B#exit
| User Name | admin |
| Password | admin123 Note: When logging in for the first time, you
                                        will be prompted to change the password.
                                        Re-set the password and use it for
                                        subsequent logins. |
ap505-13403B(config-management-policy-default)#user testuser password test@123 role helpdesk access all ap505-13403B(config-management-policy-default)#commit ap505-13403B(config-management-policy-default)#show context management-policy default telnet http server https server no ftp ssh user admin password 1 fd07f19c6caf46e5b7963a802d422a708ad39a24906e04667c8642299c8462f1 role superuser access all user testuser password 1 32472f01757293a181738674bdf068ffe0b777ce145524fc669278820ab582c0 role helpdesk access all snmp-server community 2 uktRccdr9eLoByF5PCSuFAAAAAeB78WhgTbSKDi96msyUiW+ rw snmp-server community 2 Ne+R15zlwEdhybKxfbd6JwAAAAZzvrLGzU/xWXgwFtwF5JdD ro snmp-server user snmptrap v3 encrypted des auth md5 2 WUTBNiUi7tL4ZbU2I7Eh/QAAAAiDhBZTln0UIu+y/W6E/0tR snmp-server user snmpmanager v3 encrypted des auth md5 2 9Fva4fYV1WL4ZbU2I7Eh/QAAAAjdvbWANBNw+We/xHkH9kLi no https use-secure-ciphers-only ap505-13403B(config-management-policy-default)#
