mode
      Supported in the
            following platforms:
            - Access Points –
               AP510, AP505, AP7602, AP7612, AP7622, AP7632, AP7662, AP8432,
               AP8533
mode
            [bt-sensor|le-beacon|le-sensor]Parameters
mode [bt-sensor|le-beacon|le-sensor]
                     | mode | Configures the
                        Bluetooth radio's mode of operation. The options are:
                           bt-sensor – Select this
                              option to enable the radio as a bt-sensor. Bt-sensors are Bluetooth
                              classic sensors providing robust wireless connections for legacy
                              devices. Typically these connections are not ideally suited for the
                              newer BLE (Bluetooth low energy) technology supported
                              devices. This is the default setting.le-beacon – Select this
                              option to provide Bluetooth support for newer BLE technology supported
                              devices. le-beacons are newer Bluetooth low energy beacons ideal for
                              applications requiring intermittent or periodic transfers of small
                              amounts of data. le-beacons are not designed as replacements for
                              classic beacon sensors. If selecting this option, use the beacon keyword to
                              configure the Beacon transmission period and Beacon transmission
                              pattern.le-sensor – Select this
                              option to provide Bluetooth support for LE (low energy)
                              asset tracking. When enabled, it uses the AP‘s Bluetooth radio
                              to detect BLE ‘asset tags‘ within the managed network. This
                              information is reported to a back-end server (for example, the
                              ExtremeLocation server or a third-party locationing server). |
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#mode le-beacon
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#show context
 interface bluetooth1
  shutdown
  mode le-beacon
  beacon pattern ibeacon
  ibeacon calibration-rssi -70
  ibeacon major 1110
  ibeacon minor 2210
  ibeacon uuid f2468da65fa82e841134bc5b71e0893e
Related Commands
                     |  | Reverts this Bluetooth radio‘s mode of operation to le-beacon |
