Use this command to view details of devices adopted by the logged device.
show adoption [config-errors|controllers|history|info|log|offline|pending|status|timeline]
show adoption offline {all|on <DEVICE-NAME>}
         show adoption config-errors <DEVICE-NAME>
show adoption log [adoptee|adopter {<MAC>}] {on <DEVICE-NAME>}
         show adoption [controllers {include-ipv6}|history|info|pending|status {summary}|timeline] {on <DEVICE-NAME>}
| adoption | Displays AP adoption history and status. It also displays configuration errors. |
| offline | Displays status of offline devices (unadopted
                           devices) Note: The
                              show → adoption → offline command
                           displays the following information regarding offline
                           (unadopted) devices: MAC Address, Host-Name, Type,
                           RF-Domain, Time Offline, Connected-To, and
                           Last-Know-IP. |
| config-errors <DEVICE-NAME> | Displays configuration errors for a specified adopted device
show adoption log [adoptee|adopter] {on <DEVICE-NAME>}
         | adoption | Displays adoption related information. It also displays configuration errors. |
| log [adoptee| adopter {MAC}] {on
                           <DEVICE-NAME>} {on <DEVICE-NAME>} | Displays adoption logs, for the specified device.
                        If no device name is specified, the system displays logs for the logged
                           device.
 Note: A wireless controller or service platform
                           cannot be configured as an adoptee and an adopter simultaneously. In
                           other words, an adopted wireless controller or service platform cannot be
                           configured to adopt another device and vice versa. |
show adoption [history|controllers {include-ipv6}|info|pending|status {summary}|timeline]
{on <DEVICE-NAME>}
| controllers {include-ipv6} | Displays information about adopted controllers. This is applicable in a
                        Hierarchically managed network, where site controllers are adopted by the
                        NOC controllers.
| history | Displays the adoption history of the logged device and its adopted access points |
| info | Displays adopted device information |
| pending | Displays information for devices pending adoption |
| status {summary} | Displays adoption status for the logged device. When
                        executed without using the ‘on <DEVICE-NAME>‘
                        parameter, this command displays detailed information of
                        all devices adopted by the logged device.
 Note: The
                              show → adoption → status command
                           displays the following adopted device status
                           information: Device Name, Version, CFG-Stat, Msgs,
                           Adopted-By, Last-adoption, Up-Time, and
                           IP-Address. |
| timeline | Displays the logged device‘s adoption timeline. It also shows the adoption time for the logged device‘s adopted APs. To view the adoption timeline of a specific device, use the 'on <DEVICE-NAME>' option to specify the device. |
| on <DEVICE-NAME> | The following keywords are common to all of the above parameters:
nx9500-6C8809(config)#show adoption status ------------------------------------------------------------------------------------------------------------ DEVICE-NAME VERSION CFG-STAT MSGS ADOPTED-BY LAST-ADOPTION UPTIME IPv4-ADDRESS ------------------------------------------------------------------------------------------------------------ ap7562-84A224 5.9.4.0-008D configured No nx9500-6C8809 0 days 19:20:17 0 days 19:21:33 10.234.160.6 ap7532-DF9A4C 5.9.4.0-008D configured No nx9500-6C8809 0 days 19:20:19 0 days 19:21:34 10.234.160.12 ------------------------------------------------------------------------------------------------------------- nx9500-6C8809(config)#
nx9500-6C8809nx9500-6C8809(config)#show adoption offline ------------------------------------------------------------------------------------------------- MAC HOST-NAME TYPE RF-DOMAIN TIME OFFLINE CONNECTED-TO LAST-KNOWN-IP ------------------------------------------------------------------------------------------------- 74-67-F7-5C-63-F0 ap8432-5C63F0 ap8432 default unknown None unknown 74-67-F7-07-02-35 ap8432-070235 ap8432 default unknown None unknown ------------------------------------------------------------------------------------------------- nx9500-6C8809nx9500-6C8809(config)#
nx9500-6C8809nx9500-6C8809(config)#show adoption log adoptee on ap7532-DF9A4C 2019-01-21 17:22:38:Received OK from cfgd, adoption complete to 19.6C.88.09 2019-01-21 17:22:38:Waiting for cfgd OK, adopter should be 19.6C.88.09 2019-01-21 17:22:38:Adoption state change: 'Connecting to adopter' to 'Waiting for Adoption OK' 2019-01-21 17:22:38:Adoption state change: 'No adopters found' to 'Connecting to adopter' 2019-01-21 17:22:38:Try to adopt to 19.6C.88.09 (cluster master 19.6C.88.09 in adopters) 2019-01-21 17:22:36:Got new value for MTU: 1500 Was: 0 2019-01-21 17:22:36:MLCP created VLAN link on VLAN 1, offer from B4-C7-99-6C-88-09 2019-01-21 17:22:36:Sending MLCP Request to B4-C7-99-6C-88-09 vlan 1 2019-01-21 17:22:02:Received 0 hostnames through DHCP option 191 2019-01-21 17:22:02:Adoption state change: 'Disabled' to 'No adopters found' 2019-01-21 17:22:02:DNS resolution completed, starting MLCP 2019-01-21 17:22:02:Adoption enabled due to configuration nx9500-6C8809nx9500-6C8809(config)#
