virtual-machine
      Displays the virtual-machine
         (VM) configuration, logs, and statistics
            - Service Platforms — NX 95XX, NX 96XX
Syntax
         show virtual-machine [configuration|debugging|export|statistics]
         show virtual-machine [configuration|statistics] {<VM-NAME>|team-urc|team-rls|
team-vowlan} {(on <DEVICE-NAME>)}
         show virtual-machine debugging {level|on}
         show virtual-machine debugging {level [debug|error|info|warning]} {on <DEVICE-NAME>}
         show virtual-machine export <VM-NAME> {on <DEVICE-NAME>}
         show virtual-machine [configuration|statistics] {<VM-NAME>|adsp|team-cmt}
      Parameters
                     | virtual-machine | Displays the following VM-related information: configuration or
                        statistics |
                     | configuration | Displays detailed VM configuration |
                     | statistics | Displays VM statistics |
                     | [<VM-NAME>| team-urc|team-rls| team-vowlan] | The following keywords are common to the ‘configuration‘ and
                        ‘statistics‘ parameters:
                           VM-NAME> –
                              Optional. Displays VM configuration or statistics for the virtual
                              machine identified by the <VM-NAME> keyword. Specify the VM
                              name.team-urc – Optional.
                              Displays TEAM-URC (IP-PBX) VM configuration/statisticsteam-rls – Optional.
                              Displays TEAM-RLS (Radio Link Server) VM
                              configuration/statistics<team-vowlan –
                              Optional. Displays TEAM-VoWLAN (Voice over WLAN) VM
                              configuration/statistics |
                     | on <DEVICE-NAME> | Specifies the name of the device on which the command is executed
                           <DEVICE-NAME> –
                              Specify the name of the service platform. |
                        statistics |
                     | [<VM-NAME>|adsp| team-cmt] | The following keywords are common to the ‘configuration‘ and
                           VM-NAME> –
                              name.adsp – Optional.
                              Displays Air-Defense Services Platform (ADSP) VM
                              configuration/statisticsteam-cmt – Optional.
                              Displays TEAM-CMT VM configuration/statistics |
                           <DEVICE-NAME> – Specify the name of the service platform. |
         show virtual-machine debugging {level[debug|error|info|warning]}
{on <DEVICE-NAME>}
                        statistics |
                     | debugging | Displays VM debugging logs |
                     | level [debug| error|info|warning] | Optional. Displays VM debugging logs based on the level selected. The
                        available options are:
                           debug – Displays VM
                              logs of level debug and aboveerror – Displays VM
                              logs of level errorinfo – Displays VM
                              logs of level Info and abovewarning – Displays
                              logs of level warning and above |
                           <DEVICE-NAME> –
                        statistics |
                     | export | Displays VM configuration export related information |
                     | <VM-NAME>] | Displays VM configuration export related information for the virtual
                           name. The NX 95XX and NX 96XX series service platforms will display ADSP and TEAM-CMT VM
                           configuration export information. |
                           <DEVICE-NAME> –
         nx9500-6C874D#show virtual-machine statistics
       NAME         STATE   VCPUS MEM (MB)    BRIDGE-IF             IP
  WiNG             -         -     18432    -               -
  adsp             Halted    -     -        unknown         -
  team-cmt         Halted    -     -        unknown         -
nx9500-6C874D#
         nx9500-6C874D#show virtual-machine configuration
           NAME               AUTOSTART         MEMORY(MB)          VCPUS
  WiNG                     -                 18432              -
  adsp                     ignore            12000              12
  team-cmt                 ignore            1024               1
nx9500-6C874D#
         nx9500-6C874D>show virtual-machine statistics adsp
 VM name: adsp
 Base Version    : unknown
 Install Status  : not_installed
nx9500-6C874D>
