distance (bgp-router-config)
      Configures administrative distance parameters. The distance parameter is
        a rating of the trustworthiness of a route. The higher the distance, lower is the trust
        rating. The distance can be set for each type of route indicating its trust rating.
        - Service Platforms — NX9500, NX9600
Syntax
      distance [<IP/M> <1-255> <BGP-ACL-NAME>|bgp <1-255> <1-255> <1-255>]
    Parameters
              | distance <IP/M> <1-255> <BGP-ACL-NAME> | Configures the default administrative distance,
                specified by the
                  <1-255> parameter, when the route‘s source IP address matches the specified
                    IP prefix
                      <IP/M> – Specify the IP source prefix and prefix length.
                          <1-255> – Specify the distance from 1 - 255.
                              <BGP-ACL-NAME> – Optional. Specify the BGP access list
                                name. |
              | bgp <1-255> <1-255> <1-255> | Configures the default administrative distance for
                different route types
                  <1-255> – Configures the default administrative distance for routes
                    external to this AS. Specify a value from 1 - 255.
                        internal to this AS. Specify a value from 1 - 255.
                          <1-255> – Configures the default administrative distance for local
                            routes. Specify a value from 1 - 255. |
      nx9500-6C8809(config-profile testNX9000-router-bgp)#distance bgp 200 100 200
      nx9500-6C8809(config-profile testNX9000-router-bgp)#show context
 router bgp
  bgp enable
  asn 1
  aggregate-address 116.117.118.0/24 as-set summary-only
  bgp neighbor 192.168.13.99
   remote-as 199
   maximum-prefix 9999 80 restart 50
  bgp-route-limit num-routes 10
