exclude
      Specifies the MAC addresses excluded
         from the NAC enforcement list
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         exclude <START-MAC> [<END-MAC> precedence <1-1000>|precedence <1-1000>]
      Parameters
                     | <START-MAC> | Specifies a range of MAC addresses or a single MAC address to exclude
                           <START-MAC> –
                              Specify the first MAC address in the range. Note: Use this parameter
                           to specify a single MAC address. |
                     | <END-MAC> | Specifies the last MAC address in the range (optional if a single MAC is
                        added to the list)
                           <END-MAC> –
                              Specify the last MAC address in the range. |
                     | precedence <1-1000> | Sets the rule precedence. Exclude entries are checked in the order of
                        their rule precedence.
                           <1-1000> –
                              Specify a value from 1 - 1000. |
         nx9500-6C8809(config-nac-list-test)#exclude 00-40-96-B0-BA-2A precedence 1
         nx9500-6C8809(config-nac-list-test)#show context
nac-list test
 exclude 00-40-96-B0-BA-2A 00-40-96-B0-BA-2A precedence 1
