enable
    Configures an executive password for
      this EX3500 management policyEach EX3500
        management policy can have a unique executive password with its own privilege level
        assigned. Utilize these passwords as specific EX3500 management
        sessions require priority over others.
        - Service Platforms — NX 95XX, NX 96XX, NX 7510
Syntax
      enable password [0|7|level]
      enable password [0|7] <PASSWORD>
      enable password level <0-15> [0 <PASSWORD>|7 <PASSWORD>]
    Parameters
              | enable password [0|7] <PASSWORD> | Creates a new executive password for this EX3500
                management policy. The password could be in clear text or encrypted
                  0 – Configures a clear text
                    password using ASCII characters (should be 1 - 32 characters long)7 – Configures an encrypted
                    password using HEX characters (should be 32 characters long)
                      <PASSWORD> – Specify
                        the password. |
            | enable password level <0-15> | Creates a new executive password for this EX3500
              management policy and sets its privilege level
                <0-15> – Specify the
                  privilege level for this executive password from 0 - 15. Lower values have higher
                  priority, to slot and prioritize executive passwords and EX3500 management
                  sessions. |
            | [0|7] <PASSWORD> | After setting the privilege level, configure the password, which could be in
                0 – Configures a clear text password using ASCII characters (should be 1 - 32
                  characters long)7 – Configures an encrypted password using HEX characters (should be 32
                  characters long)
                    <PASSWORD> – Specify the password. |
      nx9500-6C8809(config-ex3500-management-policy-test)#enable password level 3 7 12345678901020304050607080929291
      nx9500-6C8809(config-ex3500-management-policy-test)#show context
ex3500-management-policy test
 snmp-server notify-filter 1 remote 127.0.0.1
