deny (ip-prefix-list)
      Creates and configures a deny prefix-list rule. The deny rule specifies
        match criteria based on which prefixes received from (or transmitted to) a BGP neighbor are
        filtered. A deny action is applied on these filtered prefixes. For example, in the BGP
        router neighbor context a filter is applied using a IP prefix list. The list contains a deny
        rule with a prefix to match as 192.168.13.0/24. All prefixes received from the neighbor
        matching this prefix are denied.
        - Service Platforms — NX9500, NX9600
Syntax
      deny prefix-list <1-4292967294> [<PREFIX-TO-MATCH/MASK>|any]
      deny prefix-list <1-4292967294> [<PREFIX-TO-MATCH/MASK> {ge <0-32>|le <0-32>}|any]
    Parameters
              | deny prefix-list <1-4294967295>
                [<PREFIX-TO-MATCH/MASK>|any] | Creates and configures a deny prefix-list rule
                  <1-4294967295> – Configures a sequence number for this deny rule. Specify a
                    value from 1 - 4294967295. Within a prefix list, rules are applied in an
                    ascending order of their sequence number. Rules with lower sequence number are
                    applied first.
                      <PREFIX-TO-MATCH/MASK> – Specify the prefix to match. For example
                        10.0.0.0/8 or 192.168.13.0/24. Routes matching the specified prefix are
                          filtered.
                          ge <0-32> – Optional. Specifies a greater than or equal to value
                            for the IP prefix length (subnet mask)le <0-32> – Optional. Specifies a less than or equal to value for
                            the IP prefix length The ‘ge‘ and ‘le‘ options specify a IP prefix length range. Use
                          these options to specify a more specific (granular) prefix match
                            criteria.
                            any – Sets the prefix match criteria to any. When selected, all
                              routes are filtered, and the action applied is deny. At the backend,
                              this option sets the match criteria to 0.0.0.0/0 le 32. |
      nx9500-6C8809(config-bgp-ip-prefix-list-test)#deny prefix-list 1 168.192.13.0/24
      nx9500-6C8809(config-bgp-ip-prefix-list-test)#show context
bgp ip-prefix-list test
