ra
    Configures RA related parameters, such
      as the interval between two unsolicited successive RAs. It also allows suppression of
      RAs.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
      ra [interval <3-1800>|suppress]
    Parameters
              | interval <3-1800> | Configures the interval, in seconds, between two
                  <3-1800> – Specify a value from 3 - 1800 seconds. The default is 300
                    seconds.  Note: The router-lifetime should be at least three times the specified router
                  interval. |
              | suppress | Enables the suppression of RAs. When enabled, the transmission of RAs in IPv6
                packets is suppressed. This option is disabled by default. The no > ra
                  > suppress command enables the sending of RAs. |
      nx9500-6C8809(config-ipv6-radv-policy-test)#ra interval 200
      nx9500-6C8809(config-ipv6-radv-policy-test)#ra suppress
      nx9500-6C8809(config-ipv6-radv-policy-test)#show context
ipv6-router-advertisement-policy test
 ra suppress
 ra interval 200
 managed-config-flag
 nd-reachable-time global
 advertise mtu
 advertise hop-limit
 check-ra-consistency
 dns-server 2002::2 lifetime 3000
 domain-name TechPubs lifetime infinite
