Configures the LDAP agent‘s settings in the RADIUS server policy context
When a user's credentials are stored on an external LDAP server, the local RADIUS server cannot successfully conduct PEAP-MSCHAPv2 authentication, since it is not aware of the user's credentials maintained on the external LDAP server resource. Therefore, up to two LDAP agents can be provided locally so remote LDAP authentication can be successfully accomplished on the remote LDAP resource (using credentials maintained locally).
This feature is available to all controller, service platforms and access point models.
ldap-agent [join|join-retry-timeout|primary|secondary]
ldap-agent [join {on <DEVICE-NAME>}|join-retry-timeout <60-300>]
         ldap-agent [primary|secondary] domain-name <LDAP-DOMAIN-NAME> domain-admin-user <ADMIN-USER-NAME> domain-admin-password [0 <WORD>|2 <WORD>]
         | ldap-agent | Configures the LDAP agent‘s settings |
| join {on <DEVICE-NAME>} | Initiates the join process, which binds the
                        RADIUS server with the LDAP server‘s (Windows) domain. When successful, the
                        hostname (name of the AP, wireless controller, or service platform) is added
                        to the LDAP server‘s Active Directory.
 Note: To confirm the join status of a controller, use the show > ldap-agent > join-statuscommand. |
| join-retry-timeout <60-300> | If the join process fails (i.e. the RADIUS server
                        fails to join the LADP server‘s domain), the process is retried after a
                        specified interval. This command configures the interval (in seconds)
                        between two successive join attempts.
 Note: A retry timer is initiated as soon as the join process starts,
                           which tracks the time lapse in case of a failure. |
| primary | Configures the primary LDAP server details, such as domain name, user name, and password. The RADIUS server uses these credentials to bind with the primary LDAP server. |
| secondary | Configures the secondary LDAP server details, such as domain name, user name, and password. The RADIUS server uses these credentials to bind with the secondary LDAP server. |
| domain-name <LDAP-DOMAIN-NAME> | This keyword is common to both the ‘primary‘ and
                        ‘secondary‘ parameters.
| domain-admin-user <ADMIN-USER-NAME> | This keyword is common to both the ‘primary‘ and
| domain-admin-password [0 <WORD>| 2 <WORD>] | This keyword is common to both the ‘primary‘ and
nx9500-6C8809(config-radius-server-policy-test)#ldap-agent primary domain-name
test domain-admin-user Administrator domain-admin-password 0 test@123
         nx9500-6C8809(config-radius-server-policy-test)#show context radius-server-policy test ldap-agent primary domain-name test domain-admin-user Administrator domain-admin-password 0 test@123 nx9500-6C8809(config-radius-server-policy-test)#
| no | Removes LDAP agent settings from this RADIUS server policy |
