Creates an application policy and enters its configuration mode. Application policies allow you to define rules that dictate how each traffic type is managed on your network. An application policy contains application (Layer 7) rules.
An application rule leverages the AP's deep packet inspection (DPI) engine to detect the underlying application to which a frame or flow belongs. The rule then applies access control and quality of service actions to all the traffic associated with the application, not just traffic destined for specific IP addresses or ports. The control actions regulate both access control and traffic engineering (rate limit, marking, and prioritization) for applications and groups.
              application-policy → radius → <APPLICATION-POLICY-NAME> command to
            apply the policy to every user successfully authenticated by the RADIUS server. use → application-policy
              <APPLICATION-POLICY-NAME> command to apply the policy to all users
            assigned to the role.use → application-policy <APPLICATION-POLICY-NAME>
            command to apply the policy to all users accessing the WLAN.use → application-policy
              <APPLICATION-POLICY-NAME> command to apply the policy for the traffic
            corresponding to the bridged VLAN.
The AP3xx, AP4xx, and AP5xx model access points implement application visibility and control through the purview-application-policy.application-policy <APPLICATION-POLICY-NAME>
| application-policy <APPLICATION-POLICY-NAME> | Specify the application policy name. If an application policy with the specified name does not exist, it is created. The name should not exceed 32 characters in length. |
nx9500-6C8809(config)#application-policy TestAppliPolicy nx9500-6C8809(config-app-policy-TestAppliPolicy)#? Application Policy Mode commands: allow Allow packets deny Deny packets description Application policy description enforcement-time Configure policy enforcement based on time logging Application recognition logging mark Mark packets no Negate a command or set its defaults rate-limit Rate-limit packets clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-app-policy-TestAppliPolicy)#
| no (global-config-mode) | Removes an existing application policy |
| application | Creates an application definition and enters its configuration mode. Use this command to create customized application detection signatures. |
| application-group | Creates an application group and enters its configuration mode. |
