authentication
      Configures user authentication parameters. Users are allowed
         or denied access to the network based on the authentication parameters set.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         authentication [access-method|directed-request|server|service]
         authentication access-method [all|console|ssh|telnet|web] {(console|ssh|telnet|
web)}
         authentication directed-request
         authentication server <1-2> [host|retry-timeout-factor|timeout]
         authentication server <1-2> host <IP/HOSTNAME> {secret [0 <SECRET>|2 <SECRET>|
<SECRET>]} {port <1-65535>}
         authentication server <1-2> retry-timeout-factor <50-200>
         authentication server <1-2> timeout <3-60> {attempts <1-10>}
         authentication service <SERVICE-NAME> {protocol <AUTHENTICATION-PROTO-NAME>}
      Parameters
web)}
                     | access-method | Configures access modes for TACACS authentication. The options are:
                        console, SSH, Telnet, Web, and all. |
                     | all | Authenticates users using all access modes (console, SSH, and
                        Telnet) |
                     | console | Authenticates users using console access only |
                     | ssh | Authenticates users using SSH access only |
                     | telnet | Authenticates users using Telnet access only |
                     | web | Authenticates users using Web interface only |
                     | directed-request | Enables user to specify TACACS server to use with `@server'. This option
                        is disabled by default. Note: The specified server should be present in the configured servers
                           list. |
                     | server <1-2> | Configures a TACACS authentication server. Up to 2 TACACS servers can be
                           configured
                           <1-2> – Specify
                              the TACACS server index from 1 - 2. |
                     | host <IP/HOSTNAME> | Sets the TACACS server‘s IP address or hostname |
                     | secret [0 <SECRET>| 2 <SECRET>| <SECRET>] | Configures the secret key used to authenticate with the TACACS server
                           0 <SECRET> –
                              Configures a clear text secret2 <SECRET> –
                              Configures an encrypted secret<SECRET> –
                              Specify the secret key. The shared key should not exceed 127
                              characters. |
                     | port <1-65535> | Optional. Specifies the port used to connect to the TACACS server
                           <1-65535> –
                              Specify a value for the TCP authentication port from 1 - 65535. The
                              default port is 49. |
                           configured
                           <1-2> – Specify
                     | retry-timeout-factor <50-200> | Configures timeout scaling between two consecutive TACACS authentication
                           retries
                           <50-200> –
                              Specify the scaling factor from 50 - 200. The default is 100. A value of 100 indicates the interval between consecutive retires
                           remains the same irrespective of the number of retries. A value
                           lesser than 100 indicates the interval between consecutive retries
                           reduces with each successive retry. A value greater than 100
                           indicates the interval between consecutive retries increases with each
                           successive retry. |
                           configured
                           <1-2> – Specify
                              the TACACS server index from 1- 2. |
                     | timeout <3-60> | Configures the timeout, in seconds, for each request sent to the TACACS
                        server. This is the time allowed to elapse before another request is sent to
                        the TACACS server. If a response is received from the TACACS server within
                        this time, no retry is attempted.
                           <3-60> – Specify
                              a value from 3- 60 seconds. The default is 3 seconds. |
                     | attempts <1-10> | Optional. Indicates the number of retry attempts to make before giving
                           up
                           <1-10> – Specify
                              a value from 1 -10. The default is 3. |
                     | service <SERVICE-NAME> | Configures the TACACS authentication service name |
                     | protocol <AUTHENTICATION- PROTO-NAME> | Optional. Specify the authentication protocol used with this TACACS
                           policy Note: A maximum of
                           five entries is allowed. |
         nx9500-6C8809(config-aaa-tacacs-policy-test)#authentication directed-request
         nx9500-6C8809(config-aaa-tacacs-policy-test)#show context
aaa-tacacs-policy test
 accounting server preference authorized-server-number
 accounting auth-fail
 accounting commands
