Adds a device (access point, wireless controller, service platform, or virtual platform), as a member, to an existing cluster of devices. Assign a static IP address to the device before adding to a cluster. Note that a cluster can be only formed of devices of the same model type.
This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.join-cluster <IP> user <USERNAME> password <WORD> {level|mode}
         join-cluster <IP> user <USERNAME> password <WORD> {level [1|2]|mode [active|standby]}
         | join-cluster | Adds a access point wireless controller, or service platform to an existing cluster |
| <IP> | Specify the cluster member's IP address. |
| user <USERNAME> | Specify a user account with super user privileges on the new cluster member |
| password <WORD> | Specify password for the account specified in the user parameter |
| level [1|2] | Optional. Configures the routing level
| mode [active|standby] | Optional. Configures the cluster mode
To add a device to an existing cluster:
After adding a device to a cluster, execute the "write memory" command to ensure the configuration persists across reboots.
nx9500-6C8809>join-cluster 192.168.13.15 user admin password superuser level 1 mode standby ... connecting to 192.168.13.15 ... applying cluster configuration ... committing the changes ... saving the changes [OK] nx9500-6C8809>
nx9500-6C8809>show context ! ! Configuration of NX9500 version 7.3.1.0-002D ! ! version 2.7 ! ! ................................................................................ cluster name TechPubs cluster mode standby cluster member ip 192.168.13.15 level 1 logging on logging console warnings logging buffered warnings ! ! end nx9500-6C8809>
| create-cluster | Creates a new cluster on the specified device |
| cluster | Initiates cluster context. The cluster context enables centralized management and configuration of all cluster members from any one member. |
