Manages file archive operations
archive tar /table [<FILE>|<URL>]
archive tar /create [<FILE>|<URL>] <FILE>
archive tar /xtract [<FILE>|<URL>] <DIR>
| tar | Manipulates (creates, lists, or extracts) a tar file |
| /table | Lists the files in a tar file |
| <FILE> | Defines a tar filename |
| <URL> | Sets the tar file URL |
| tar | Manipulates (creates, lists or extracts) a tar file |
| /create | Creates a tar file |
| <FILE> | Defines tar filename |
| /xtract | Extracts content from a tar file |
| <DIR> | Specify a directory name. When used with /create, dir is the source directory for the tar file. When used with /xtract, dir is the destination file where contents of the tar file are extracted. |
Following examples show how to zip the folder flash:/log/?
nx9500-6C8809#dir flash:/ Directory of flash:/ -rw- 62937 Tue Nov 24 16:00:06 2015 run-config-backup.txt drwx Mon Apr 3 12:40:23 2017 crashinfo drwx Wed Mar 22 13:58:28 2017 upgrade drwx Mon Sep 28 09:48:33 2015 tmptpd drwx Wed Apr 5 11:20:11 2017 log drwx Thu Mar 30 15:07:54 2017 archived_logs drwx Tue May 24 22:23:54 2016 cache drwx Thu Feb 19 08:53:45 2015 floorplans -rw- 42018304 Tue Sep 27 10:19:24 2016 in.tar drwx Tue Jan 17 10:02:01 2017 hotspot nx9500-6C8809#
nx9500-6C8809#archive tar /create flash:/in.tar flash:/log/ log/nsightd.log.1 log/nsight_reportd.log log/messages.1.log log/martdb.log log/reportd.log.2 log/adopts.log.2 log/mongod.log.2 log/dpd2.log log/nsight_server.log log/mart_websock_server.log log/nuxi/ log/nuxi/beanyaml.log log/nuxi/statsreqresp.1.log log/nuxi/hadoop.log.2014-08-03 log/nuxi/puts.log log/nuxi/copy2w.log log/nuxi/obj2yaml.log log/nuxi/infl.log --More-- nx9500-6C8809#
nx9500-6C8809#dir flash:/ Directory of flash:/ -rw- 62937 Tue Nov 24 16:00:06 2015 run-config-backup.txt drwx Thu Sep 22 00:12:07 2016 crashinfo drwx Sat Sep 17 05:14:43 2016 upgrade drwx Mon Sep 28 09:48:33 2015 tmptpd drwx Tue Sep 27 09:59:12 2016 log drwx Mon Sep 26 09:58:54 2016 archived_logs drwx Tue May 24 22:23:54 2016 cache drwx Thu Feb 19 08:53:45 2015 floorplans -rw- 42018304 Tue Sep 27 10:19:24 2016 in.tar drwx Mon Sep 15 03:40:02 2014 hotspot nx9500-6C8809#
