spanning-tree
      Displays spanning tree utilization
         information
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         show spanning-tree mst {configuration|detail|instance|on}
         show spanning-tree mst {configuration} {(on <DEVICE-NAME>)}
         show spanning-tree mst {detail} {interface|on}
         show spanning-tree mst {detail} interface {<INTERFACE-NAME>|ge <1-4>|me1|
port-channel <1-2>|pppoe1|vlan <1-4094>|wwan1} {(on <DEVICE-NAME>)}
         show spanning-tree mst {instance <1-15>} {interface <INTERFACE-NAME>}
      Parameters
                     | spanning-tree | Displays spanning tree utilization information |
                     | mst | Displays Multiple Spanning Tree (MST) related information |
                     | configuration {on <DEVICE-NAME>} | Optional. Displays MST configuration
                           on <DEVICE-NAME>
                              – Optional. Displays MST configuration on a specified device
                                 <DEVICE-NAME> – Specify the name of the AP,wireless
                                    controller, or service platform. |
                     | spanning-tree | Displays spanning tree information |
                     | mst | Displays MST configuration |
                     | detail | Optional. Displays detailed MST configuration, based on the parameters
                        passed |
                     | interface [<INTERFACE>| age <1-4>|me1| port-channel
                        <1-2>| pppoe1| vlan <1-4094> wwan1] | Displays detailed MST configuration for a specified interface
                           <INTERFACE> –
                              Displays detailed MST configuration for a specified interface. Specify
                              the interface name.age <1-4> –
                              Displays GigabitEthernet interface MST configuration
                                 <1-4> –
                                    Select the GigabitEthernet interface index from 1 - 4.me1 – Displays
                              FastEthernet interface MST configurationport-channel –
                              Displays port channel interface MST configuration
                                 <1-2> –
                                    Select the port channel interface index from 1 - 2.pppoe1 – Displays PPP
                              over Ethernet interface MST configurationvlan – Displays VLAN
                                 <1-4094> –
                                    Select the SVI VLAN ID from 1 - 4094.wwan1 – Displays
                              Wireless WAN interface MST configuration |
                     | on <DEVICE-NAME> | The following keyword is common to all interfaces: Optional. Displays
                           detailed MST configuration on a specified device
                           <DEVICE-NAME> –
                              Specify the name of the AP, wireless controller, or service
                              platform. |
                     | mst | Displays MST configuration. Use additional filters to view specific
                        details. |
                     | instance <1-15> | Optional. Displays information for a particular MST instance
                           <1-15> – Specify
                              the instance ID from 1 - 15. |
                     | interface <INTERFACE-NAME> | Optional. Displays MST configuration for a specific interface instance.
                        The options are:
                           <INTERFACE-NAME>
                              – Displays MST configuration for a specified interface. Specify the
                              interface name. |
                     | on <DEVICE-NAME> | Optional. Displays MST configuration on a specified device
                           <DEVICE-NAME> –
                              platform. |
         nx9500-6C8809#show spanning-tree mst configuration
%  MSTP Configuration Information for bridge 1 :
%  Format Id      : 0
%  Name           : My Name
%  Revision Level : 0
%  Digest         : 0xac36177f50283cd4b83821d8ab26de62
nx9500-6C8809#
         nx9500-6C8809#show spanning-tree mst detail interface ge 1
% Bridge up - Spanning Tree Disabled
% CIST Root Path Cost 0  - CIST Root Port 0 - CIST Bridge Priority 32768
% Forward Delay 15 - Hello Time 2 - Max Age 20 - Max hops 20
% 1: CIST Root Id 800000157081742e
% 1: CIST Reg Root Id 800000157081742e
% 1: CIST Bridge Id 800000157081742e
% portfast bpdu-filter disabled
% portfast bpdu-guard disabled
% portfast portfast errdisable timeout disabled
% portfast errdisable timeout interval 300 sec
% cisco interoperability not configured - Current cisco interoperability off
%   ge1: Port 2001 - Id 87d1 - Role Disabled - State Forwarding
%   ge1: Designated External Path Cost 0 - Internal Path Cost 0
--More--
nx9500-6C8809#
