auto-learn
      Profile Config Commands
Enables controllers or service platforms to maintain a local configuration record of devices requesting adoption and provisioning. The command also enables learning of a device‘s host name via DHCP options.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
auto-learn [host-name-via-dhcp <WORD>|staging-config]Parameters
                     | auto-learn
                        [host-name-via-dhcp <WORD>| staging-config] | Enables
                        auto-learning of:
                           host-name-via-dhcp – A
                              device‘s host name via DHCP option.
                                 <WORD> –
                                    Provide the optional template with substitution token. For
                                    example, 'outdoor-$DHCP[1:3]-ap', where the $DHCP token
                                    references DHCP Option value received by the adopting device.
                                    The $DHCP token should be present. This option is disabled by
                                    default.staging-config – The
                              network configuration of devices requesting adoption. This option is
                              enabled by default. For dependent access points that are pre-staged
                              prior to deployment, it is recommended that the
                              auto-learn-staging-config parameter remains enabled so that hostnames,
                              VLAN and IP addressing configuration can be maintained upon initial
                              adoption. However, if dependent access points are to be centrally
                              managed and configured, it is recommended that the
                              auto-learn-staging-config parameter be disabled |
nx9500-6C8809(config-profile-test)#auto-learn staging-config
nx9500-6C8809(config-profile-test)#show context include-factory | include auto-learn
 no auto-learn host-name-via-dhcp
Related Commands
                     | no | Disables automatic recognition of devices‘ hostname and devices pending adoption |
