ip
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
ip [arp [header-mismatch-validation|trust]|dhcp trust]
      Parameters
                     | arp
                        [header-mismatch-validation| trust] | Configures ARP
                        packet settings
                              – Enables matching of source MAC address in the ARP and Ethernet
                              headers to check for mismatch. This option is disabled by
                              default.trust – Enables trust
                              state for ARP responses on this interface. When enabled, ARP packets
                              received on this port are considered trusted and information from
                              these packets is used to identify rogue devices within the network.
                              This option is disabled by default. |
                     | dhcp
                        trust | Enables trust
                        state for DHCP responses on this interface. When enabled, only DHCP
                        responses are trusted and forwarded on this port, and a DHCP server can be
                        connected only to a DHCP trusted port. This option is enabled by
                        default. |
nx9500-6C8809(config-profile-testnx5500-if-ge1)#ip dhcp trust
nx9500-6C8809(config-profile-testnx5500-if-ge1)#ip arp header-mismatch-validation
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
 interface ge1
  description "This is GigabitEthernet interface for Royal King"
  duplex full
  dot1x supplicant username Bob password 0 test@123
  ip dhcp trust
  qos trust dscp
  qos trust 802.1p
  channel-group 1
Related Commands
                     | no | Removes the ARP and DHCP components configured for this interface |
