session-resumption
      Enables session resumption or fast re-authentication by
         using cached attributes. This feature controls the volume and duration cached data is
         maintained by the server policy, upon termination of a server policy session. The
         availability and quick retrieval of the cached data speeds up session resumption.This feature is disabled by default.
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
Syntax
         session-resumption {lifetime|max-entries}
         session-resumption {lifetime <1-24> {max-entries <10-1024>}|max-entries <10-1024>}
      Parameters
                        <10-1024>} | Optional. Sets the lifetime of cached entries
                           <1-24> – Specify the lifetime period from 1 -
                              24 hours (default is 1 hour)
                                 max-entries – Optional. Configures the
                                    maximum number of entries in the cache
                                       <10-1024> – Sets the maximum
                                          number of entries in the cache from 10 - 1024 (default is
                                          128 entries) |
                     | max-entries <10-1024> | Optional. Configures the maximum number of
                           <10-1024> – Sets the maximum number of entries
                              in the cache from 10 - 1024 (default is 128 entries) |
         nx9500-6C8809(config-radius-server-policy-test)#session-resumption lifetime 10 max-entries 11
         nx9500-6C8809(config-radius-server-policy-test)#show context
radius-server-policy test
 proxy retry-delay 8
 proxy retry-count 4
 proxy realm test1 server 172.16.10.7 port 1025 secret 0 test1123
 ldap-server primary host 172.16.10.19 port 162 login "test" bind-dn "bind-dn1" base-dn "bas-dn1" passwd 0 test@123 passwd-attr test123 group-attr group1 group-filter "groupfilter1" group-membership groupmembership1 net-timeout 2
      Related Commands
                     | no | Disables session resumption on this RADIUS server
                        policy |
