probe-response
         interface-config-radio-instance
         Configures transmission
            parameters for probe response frames sent by the access point in
            response to probe requests received from clients.
      Supported in the
                following platforms:
                - Access Points — AP3000/X, AP5010, AP310i/e, AP410i/e,
                        AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612,
                    AP7632, AP7662, AP8432, AP8533
probe-response [ac-strict|rate|retry|rssi-threshold]
         probe-response rate [follow-probe-request|highest-basic|lowest-basic]
         probe-response rssi-threshold <-128--40>
      Parameters
         probe-response ac-strict
                     | probe-response ac-strict | Strictly restricts sending of
                        probe-response frames to 802.11ac capable wireless clients. When enabled,
                        the radio will only respond to probe-request frames received from 802.11ac
                        capable clients. |
         probe-response retry
                     | probe-response retry | Enables retransmission of probe-response
                        frames if no acknowledgment is received from the client.
                        This option is enabled by default. |
                     | probe-response rate | Configures the rates used for transmission
                        of probe response frames. The tx-rate options available
                        for transmitting probe response frames are:
                        follow-probe-request, highest-basic,
                        lowest-basic. |
                     | follow-probe-request | Transmits probe responses at the same rate
                        as the received request (default setting) |
                     | highest-basic | Uses the highest configured basic
                        rate |
                     | lowest-basic | Uses the lowest configured basic
                        rate |
                        <-128--40> | Ignores probe request from client if the
                        received signal strength is less than the RSSI threshold
                        specified here <-128--40> – Specify
                           a value from -128 - -40. |
         nx9500-6C8809(config-profile-testAP510-if-radio1)#probe-response rate highest-basic
nx9500-6C8809(config-profile-testAP510-if-radio1)#probe-response retry
nx9500-6C8809(config-profile-testAP510-if-radio1)#probe-response rssi-threshold -60
nx9500-6C8809(config-profile-testAP510-if-radio1)#show context
 interface radio1
