tunnel
         bridge
Enables tunneling of unicast messages, to unknown MAC destinations, on the selected VLAN bridge
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
tunnel [rate-limit|unknown-unicast]
         tunnel rate-limit level2 rate <50-1000000> max-burst-size <2-1024> {red-threshold [background <0-100>|best-effort <0-100>|video <0-100>|voice <0-100>]}
      Parameters
                     | tunnel
                        <2-1024> | Configures a
                        rate-limit parameters (max-burst-size and rate) for tunneled VLAN traffic
                        over level 2 MiNT links
                           rate – Optional.
                              Configures the data rate, in kilobits per second, for the incoming and
                              outgoing extended VLAN traffic tunneled over MiNT level 2 links
                                 <50-1000000> –
                                    Specify a value from 50 - 1000000 Kbps. The default is 5000
                                    Kbps.max-burst-size –
                              Optional. Configures the maximum burst size
                                 <2-1024> –
                                    Specify the maximum burst size from 2 - 1024 kbytes. The default
                                    is 320 kbytes. After specifying the
                           max-burst-size, optionally specify the red-threshold value for the
                           different traffic types. The red-threshold is configured as a % of the
                           specified max-burst-size.
                           red-threshold – Optional.
                              Configures the random early detection (red) threshold for the
                                 background –
                                    Configures the red-threshold for low priority traffic from 0 -
                                    100. The default is 50% of the specified max-burst-size.best-effort –
                                    Configures the red-threshold for normal priority traffic from 0
                                    - 100. The default is 50% of the specified max-burst-size.video – Configures
                                    the red-threshold for video traffic from 0 - 100. The default is
                                    25% of the specified max-burst-size.voice – Configures
                                    the red-threshold for voice traffic from 0 - 100. The default is
                                    0% of the specified max-burst-size. |
tunnel unknown-unicast
                     | tunnel
                        unknown-unicast | Enables tunneling of unicast packets destined for unknown MAC addresses |
nx9500-6C8809(config-profile TestAP8432-bridge-vlan-1)#tunnel unknown-unicast
nx9500-6C8809(config-profile TestAP8432-bridge-vlan-1)#no tunnel unknown-unicast
nx9500-6C8809(config-profile TestAP8432-bridge-vlan-1)#show context
 bridge vlan 1
  ip igmp snooping
  ip igmp snooping querier
Related Commands
                     | no | Disables tunneling of unicast messages, to unknown MAC destinations, on the selected VLAN bridge |
