| aaa | Enables and configures logging of the following authentication,
                        authorization, and accounting related events:
                           radius-discon-msg –
                              RADIUS disconnection messageradius-session-expired
                              – RADIUS session expired messageradius-session-not-started – RADIUS session not started messageradius-vlan-update –
                              RADIUS VLAN update message |
                     | adapt | Enables and configures logging of the following adaptivity module
                        related events:
                           adaptivity-change –
                              Event adaptivity change adaptivity-rehome –
                              Event adaptivity rehome |
                     | adopt-services | Enables and configures the logging of adopted services related
                        events |
                     | adv-wips | Enables and configures the logging of advanced WIPS related
                        events |
                     | ap | Enables and configures logging of the following AP related events:
                           adopted – Event AP
                              adopted adopted-to-controller
                              – Event AP adopted to wireless controller ap-adopted – Event
                              access port adopted ap-autoup-done – Event
                              AP autoup done ap-autoup-fail – Event
                              AP autoup fail ap-autoup-needed –
                              Event AP autoup needed ap-autoup-no-need –
                              Event AP autoup not needed ap-autoup-reboot –
                              Event AP autoup reboot ap-autoup-timeout –
                              Event AP autoup timeout ap-autoup-ver – Event
                              AP autoup version ap-reset-detected –
                              Event access port reset detected ap-reset-request –
                              Event access port user requested reset ap-timeout – Event
                              access port timed out ap-unadopted – Event
                              access port unadopted image-parse-failure –
                              Event image parse failure legacy-auto-update –
                              Event legacy auto update no-image-file – Event
                              no image file offline – Event AP
                              detected as offlineonline – Event offline
                              AP detected as onlinereset – Event reset sw-conn-lost – Event
                              software connection lost unadopted – Event
                              unadopted  |
                     | bt | Enables and configures logging of the following bluetooth related
                        events:
                           bt-started – Event
                              bluetooth (bt) started bt-state-change –
                              Event bt state change |
                     | captive-portal | Enables and configures logging of the following captive portal (hotspot)
                        related events:
                           allow-access – Event
                              client allowed access auth-failed – Event
                              client authentication failed auth-success – Event
                              client authentication success client-disconnect –
                              Event client disconnected client-removed – Event
                              client removed data-limit-exceed –
                              Event client data limit exceeded flex-log-access –
                              Event flexible log access granted to client inactivity-timeout –
                              Event client time-out due to inactivity page-cre-failed –
                              Event page creation failure purge-client – Event
                              client purged session-timeout –
                              Event session timeout vlan-switch – Event
                              client switched VLAN |
                     | cdp | Enables and configures logging of the following CISCO Discovery
                           Protocol (CDP) related event:
                           duplex-mismatch –
                              Event duplex mismatch detected between CDP neighbors |
                     | certmgr | Enables and configures logging of the following certificate manager
                        related events:
                           ca-cert-actions-failure – Event CA certificate actions failure ca-cert-actions-success – Event CA certificate actions success ca-key-actions-failure
                              – Event CA key actions failure ca-key-actions-success
                              – Event CA key actions success cert-expiry – Event
                              certificate expiry crl-actions-failure –
                              Event Certificate Revocation List (CRL ) actions failure crl-actions-success –
                              Event CRL actions success csr-export-failure –
                              Event CSR export failure csr-export-success –
                              Event CSR export success delete-trustpoint-action – Event delete trustpoint action export-trustpoint –
                              Event trustpoint exportedimport-trustpoint –
                              Event trustpoint importedrsa-key-actions-failure – Event RSA key actions failure rsa-key-actions-success – Event RSA key actions success svr-cert-actions-success – Event server certificate actions success svr-cert-actions-failure – Event server certificate actions failure
                     | certmgr-lite | Enables and configures logging of certificate manager (lite version)
                        related event messages |
                     | cfgd | Enables and configures logging of the following configuration daemon
                        module related events:
                           acl-attached-altered –
                              Event Access List (ACL) attached altered acl-rule-altered –
                              Event ACL rule altered  |
                     | cluster | Enables and configures logging of the following cluster module related
                           events:
                           cmaster-cfg-update-fail – Event cluster master config update
                              failedmax-exceeded – Event
                              maximum cluster count exceededstate-change – Event
                              cluster state change (active/inactive)state-change-active –
                              Event cluster state change to activestate-change-inactive
                              – Event cluster state change to inactivestate-retain-active –
                              Event cluster state retained as active |
                     | crm | Enables and configures logging of the following Critical Resource
                           Monitoring (CRM) related event
                           critical-resource-down
                              – Event critical resource goes downcritical-resource-up –
                              Event critical resource comes up  |
                     | device | Enables and configures the logging of device module related
                        events |
                     | database | Enables and configures logging of the following error conditions in the
                        captive-portal/NSIght database:
                           database-election-fail
                              – Event primary database node selection failure. Requires manual
                              intervention to select primary database node.database-exception –
                              Event database may need to be dropped and device restarteddatabase-low-disk-space – Event database low disk spacedatabase-new-state –
                              Event database state changedatabase-op-failure –
                              Event database failuredatabase-set-name-mismatch – Event replica-set not enabled on
                              hostdatabase-storage-mismatch – Event database mismatch. All database
                              files must be removed.operation-complete –
                              Event database operation completed successfullyoperation-failed –
                              Event database operation failure |
                     | dhcpsvr | Enables and configures logging of the following DHCP server related
                           events:
                           dhcp-start – Event
                              DHCP server started dhcpsvr-stop – Event
                              DHCP sever stopped relay-iface-no-ip –
                              Event no IP address on DHCP relay interface relay-no-iface – Event
                              no interface for DHCP relay relay-start – Event
                              relay agent startedrelay-stop – Event
                              DHCP relay agent stopped |
                     | diag | Enables and configures logging of the following diagnostics module
                        related events:
                           autogen-tech-sprt –
                              Event autogen technical support buf-usage – Event
                              buffer usage cpu-load – Event CPU
                              load cpu-usage-too-high –
                              Event CPU usage high cpu-usage-too-high-recovery – Event recovery from high CPU usage disk-usage – Event
                              disk usage elapsed-time – Event
                              elapsed time fan-underspeed – Event
                              fan underspeed fd-count – Event
                              forward count free-flash-disk –
                              Event free flash disk free-flash-inodes –
                              Event free flash inodes free-nvram-disk –
                              Event free nvram disk free-nvram-inodes –
                              Event free nvram inodes free-ram – Event free
                              ram free-ram-disk – Event
                              free ram disk free-ram-inodes –
                              Event free ram inodes head-cache-usage –
                              Event head cache usage high-temp – Event high
                              temp ip-dest-usage – Event
                              ip destination usage led-identify – Event
                              led identify low-temp – Event low
                              temp mem-usage-too-high –
                              Event memory usage high mem-usage-too-high-recovery – Event recovery from high memory usage new-led-state – Event
                              new led state over-temp – Event over
                              temp over-voltage – Event
                              over voltage poe-init-fail – Event
                              PoE init fail poe-power-level –
                              Event PoE power level poe-read-fail – Event
                              PoE read fail poe-state-change –
                              Event PoE state change poe-state-change –
                              Event PoE state change pwrsply-fail – Event
                              failure of power supply raid-degraded – Event
                                 Redundant Array of Independent Disks (RAID) degraded raid-error – Event
                              RAID error ram-usage – Event ram
                              usage under-voltage – Event
                              under voltage wd-reset-sys – Event
                              wd reset system wd-state-change –
                              Event wd state change  |
                     | dot11 | Enables and configures logging of the following 802.11 management module
                        related events:
                           client-assoc-ignored –
                              Wireless client association ignored eventclient-associated –
                              Wireless client associated event client-denied-assoc –
                              Event client denied association client-disassociated –
                              Wireless client disassociated country-code – Event
                              country code appliedcountry-code-error –
                              Event country code error eap-cached-keys –
                              Event Extensible Authentication Protocol (EAP) cached keys eap-client-timeout –
                              Event EAP client timeout eap-failed – Event EAP
                              failed eap-opp-cached-keys –
                              Event EAP opp cached keys eap-preauth-client-timeout – Event EAP pre authentication client
                              timeout eap-preauth-failed –
                              Event EAP pre authentication failed eap-preauth-server-timeout – Event EAP pre authentication server
                              timeout eap-preauth-success –
                              Event EAP pre authentication success eap-server-timeout –
                              Event EAP server timeout eap-success – Event
                              EAP success ft-roam-success –
                              Event client fast BSS transition gal-rx-request – Event
                              GAL request received event gal-tx-response –
                              Event response sent to GAL requestgal-validate-failed –
                              Event GAL validation failedgal-validate-req –
                              Event GAL validation requestgal-validate-success –
                              Event GAL validation successkerberos-client-success – Event client Kerberos authentication
                              successkerberos-wlan-failed –
                              Event WLAN Kerberos authentication failed kerberos-wlan-success
                              – Event WLAN Kerberos authentication successkerberos-wlan-timeout
                              – Event Kerberos authentication timed outmove-operation-success
                              – Event move operation success tkip-cntrmeas-end –
                              Event TKIP countermeasures endedtkip-cntrmeas-start –
                              Event TKIP countermeasures initiatedtkip-mic-fail-report –
                              Event TKIP MIC failure reporttkip-mic-failure –
                              Event TKIP MIC check failedneighbor-denied-assoc
                              – Event neighbor denied association unsanctioned-ap-active
                              – Event unsanctioned AP active unsanctioned-ap-inactive – Event unsanctioned AP inactive unsanctioned-ap-status-change – Event unsanctioned AP status
                              changevoice-call-completed –
                              Event voice call completed voice-call-established
                              – Event voice call established voice-call-failed –
                              Event voice call failed wlan-time-access-disable – Event WLAN disabled by time-based-access wlan-time-access-enable – Event WLAN re-enabled by time-based-access wpa-wpa2-failed –
                              Event WPA-WPA2 failed wpa-wpa2-key-rotn –
                              Event WPA-WPA2 key rotn wpa-wpa2-success –
                              Event WPA-WPA2 success  |
                     | dot1x | Enables and configures logging of the following 802.1X authentication
                        related events:
                           dot1x-failed – Event
                              EAP authentication failure dot1x-success – Event
                              dot1x-success  |
                     | fa | Enables and configures logging of fabric attach
                        related events:
                           fa-accepted – Event fa-accepted  fa-pending – Event fa-pending  |
                     | fwu | Enables and configures logging of the following firmware update
                        (FWU) related events:
                           fwuaborted – Event fwu
                              aborted fwubadconfig – Event
                              fwu aborted due to bad config fwucorruptedfile –
                              Event fwu aborted due to corrupted file fwucouldntgetfile –
                              Event fwu aborted because the system could not get file fwudone – Event fwu
                              done fwufileundef – Event
                              fwu aborted due to file undefined fwunoneed – Event fwu
                              no need fwuprodmismatch –
                              Event fwu aborted due to product mismatch fwuserverundef – Event
                              fwu aborted due to server undefined fwuserverunreachable –
                              Event fwu aborted due to server unreachable fwusignmismatch –
                              Event fwu aborted due to signature mismatch fwusyserr – Event fwu
                              aborted due to system error fwuunsupportedhw –
                              Event fwu aborted due to unsupported hardware fwuunsupportedmodelnum
                              – Event fwu aborted due to unsupported FIPS model number fwuvermismatch – Event
                              fwu aborted due to version mismatch  |
                     | isdn | Configures file Integrated Service Digital Network (ISDN) module
                        related event s
                           isdn-alert – Event
                              ISDN alert isdn-crit – Event ISDN
                              critical isdn-debug – Event
                              ISDN debug isdn-emerg – Event
                              ISDN emergency isdn-err – Event ISDN
                              error isdn-info – Event ISDN
                              info isdn-notice – Event
                              ISDN notice isdn-warning – Event
                              ISDN warning  |
                     | l2gre | Enables and configures logging of the following Layer 2 GRE
                        (L2GRE) tunnel related events:
                           l2gre-tunnel-down –
                              Event L2GRE tunnel downl2gre-tunnel-failover
                              – Event L2GRE tunnel failoverl2gre-tunnel-up –
                              Event L2GRE tunnel up |
                     | l2tpv3 | Enables and configures logging of the following Layer 2 TPV3
                        (L2TPv3) tunnel related events:
                           l2tpv3-tunnel-down –
                              Event L2TPv3 tunnel down l2tpv3-tunnel-up –
                              Event L2TPv3 tunnel up  |
                     | licmgr | Enables and configures logging of the following license manager module
                        related events:
                           lic-installed-count –
                              Event total number of license installed count lic-installed-default
                              – Event default license installation lic-installed – Event
                              license installed lic-invalid – Event
                              license installation failed lic-removed – Event
                              license removed  |
                     | lldp | Enables and configures logging of the following Link Layer Discovery
                           Protocol (LLDP) related events:
                           lldp-loop-detected –
                              Event layer 2 switching looplldp-loop-recovery –
                              Event recovery from layer 2 switching loop |
                     | mgmt | Enables and configures logging of the following management services
                           log-http-init – Event
                              Web server startedlog-http-local-start –
                              Event Web server started in local modelog-http-start – Event
                              Web server started in external modelog-https-start –
                              Event secure Web server startedlog-https-wait – Event
                              waiting for Web server to startlog-key-deleted –
                              Event RSA key associated with SSH is deletedlog-key-restored –
                              Event RSA key associated with SSH is addedlog-trustpoint-deleted
                              – Event trustpoint associated with HTTPS is deleted |
                     | mesh | Enables and configures logging of the following mesh module related
                           events:
                           mesh-link-down – Event
                              mesh link down mesh-link-up – Event
                              mesh link up meshpoint-down – Event
                              meshpoint down meshpoint-loop-prevent-off – Event meshpoint loop prevent off meshpoint-loop-prevent-on – Event meshpoint loop prevent on meshpoint-path-change
                              – Event meshpoint-path-change meshpoint-root-change
                              – Event meshpoint-root-change meshpoint-up – Event
                              meshpoint up  |
                     | nsm | Configures Network Service Module (NSM) related event
                           dhcpc-err – Event DHCP
                              certification error dhcpdefrt – Event DHCP
                              defrt dhcpip – Event DHCP IP dhcpipchg – Event DHCP
                              IP change dhcpipnoadd – Event
                              DHCP IP overlaps static IP address dhcplsexp – Event DHCP
                              lease expiry dhcpnak – Event DHCP
                              server returned DHCP NAK responsedhcpnodefrt – Event
                              interface no default route if-failback – Event
                              interface failback if-failover – Event
                              interface failover ifdown – Event
                              interface down ifipcfg – Event
                              interface IP config ifup – Event interface
                              up nsm-ntp – Event
                              translate host name  |
                     | pm | Configures process monitor module related event s
                           procid – Event proc ID
                              generatedprocmaxrstrt – Event
                              proc max restart procnoresp – Event
                              proc no response procrstrt – Event proc
                              restart procstart – Event proc
                              start procstop – Event proc
                              stop procsysrstrt – Event
                              proc system restart startupcomplete –
                              Event startup complete  |
                     | radconf | Enables and configures logging of the following RADIUS configuration
                        daemon related events:
                           could-not-stop-radius
                              – Event could not stop RADIUS server radiusdstart – Event
                              RADIUS server started radiusdstop – Event
                              RADIUS server stopped  |
                     | radio | Enables and configures logging of the following radio module related
                           events:
                           acs-scan-complete –
                              Event ACS scan completedacs-scan-started –
                              Event ACS scan startedcb-associated – Event
                              client-bridge access point associates with an infrastructure access
                              pointcb-roam – Event
                              client-bridge access point roams from one infrastructure access point
                              to another infrastructure access pointcb-wired-client-added
                              – Event wired client is added to the client-bridgecb-wired-client-removed – Event wired client is removed from the
                              client-bridgechannel-country-mismatch – Event channel and country of operation
                              mismatchradar-det-info –
                              Detected radar info radar-detected – Event
                              radar detected radar-scan-completed –
                              Event radar scan completed radar-scan-started –
                              Event radar scan started radio-antenna-error –
                              Event invalid antenna type on this radio radio-antenna-setting
                              – Event antenna type setting on this radio radio-state-change –
                              Event radio state change resume-home-channel –
                              Event resume home channel  |
                     | rasst | Enables and configures the logging of roaming assist module related
                        events |
                     | smrt | Enables and configures logging of the following SMART RF module related
                           events:
                           calibration-done –
                              Event calibration done calibration-started –
                              Event calibration started channel-change – Event
                              channel change config-cleared –
                              Configuration cleared event cov-hole-recovery –
                              Event coverage hole recovery cov-hole-recovery-done
                              – Event coverage hole recovery done interference-recovery
                              – Event interference recovery neighbor-recovery –
                              Event neighbor recovery power-adjustment –
                              Event power adjustment root-recovery – Event
                              meshpoint root recovery  |
                     | smtpnot | Enables and configures logging of the following SMTP module related
                           events:
                           cfg – Event cfg cfginc – Event cfg inc net – Event net proto – Event proto smtpauth – Event SMTP
                              authentication smtperr – Event SMTP
                              error smtpinfo – Event SMTP
                              information  |
                     | system | Enables and configures logging of the following system module related
                           events:
                           clock-reset – Event
                              clock reset cold-start – Event
                              cold start config-commit – Event
                              configuration commit config-revision –
                              Event config-revision donedevup-rfd-fail – Event
                              device-upgrade failed on rf-domain manager managed devicesguest-user-exp – Event
                              guest user purging http-err – Event Web
                              server did not start login – Event
                              successful login login-fail – Event
                              login fail. Occurs when user authentication fails.login-fail-access –
                              Event login fail access. Occurs in case of access violation.login-fail-bad-role –
                              Event login fail bad role. Occurs when user uses an invalid role to
                              logon.login-lockout – Event
                              user account locked out message. Occurs when a user account is locked
                              due to exceeding of maximum number failed login attempts threshold.
                              Configure this event notification only if the max-fail and
                              lockout-time parameters have been configured in the management-policy
                              context. For more information, see password-entry.login-unlocked – Event
                              user account un-locked. Occurs when a locked user account is
                              re-activated. Enable this event notification only if the max-fail and
                              context. For more information, see password-entry.logout – Event logout maat-light – Event
                              action on RIM (Research in Motion) radio(s) from the Maat
                              light modulepanic – Event panic periodic-heart-beat –
                              Event periodic heart beat procstop – Event proc
                              stop server-unreachable –
                              Event server-unreachable system-autoup-disable
                              – Event system autoup disable system-autoup-enable –
                              Event system autoup enable t5-config-error –
                              Event t5-config-errorui-user-auth-fail –
                              Event user authentication fail ui-user-auth-success –
                              Event user authentication success warm-start – Event
                              warm start warm-start-recover –
                              Event recovery from warm start  |
                     | test | Enables and configures logging of the following test module related
                           events:
                           testalert – Event test
                              alert testargs – Event test
                              arguments testcrit – Event test
                              critical testdebug – Event test
                              debug testemerg – Event test
                              emergency testerr – Event test
                              error testinfo – Event test
                              information testnotice – Event
                              test notice testwarn – Event test
                              warning  |
                     | vrrp | Enables and configures logging of the following Virtual Router
                           Redundancy Protocol (VRRP) related events:
                           vrrp-monitor-change –
                              Event VRRP monitor link state change vrrp-state-change –
                              Event VRRP state transition vrrp-vip-subnet-mismatch – Event VRRP IP not overlapping with an
                              interface addresses  |
                     | webf | Enables and configures logging of the following Web Filtering (webf)
                           malform-url-request –
                              Event malformed URL requestno-parent-engine –
                              Event ‘no session to URL classification server‘srvr-connect-fail –
                              Event URL classification server unreachableurl-blocked – Event
                              URL blockedwebf-lic-acquired –
                              Event webf license acquiredwebf-lic-missing –
                              Event webf license missingwebf-lic-revoked –
                              Event webf license revoked |
                     | wips | Enables and configures logging of the following
                        Wireless IPS module related events:
                           air-termination-active – Event air termination
                                 activeair-termination-ended – Event air
                                 termination
                                 ended air-termination-inactive – Event
                                 air termination
                                 inactive air-termination-initiated –
                                 initiated rogue-ap-active – Event rogue
                                 AP active rogue-ap-inactive – Event rogue
                                 AP inactive unsanctioned-ap-active –
                                 unsanctioned AP
                                 Event unsanctioned AP changed
                                 state wips-client-blacklisted – Event
                                 WIPS client blacklisted wips-client-rem-blacklist – Event WIPS client rem
                              blacklist wips-event – Event WIPS event triggered  Note: Air-termination is not supported on AP505 and
                           AP510 model access points. |
                     | email | Sends e-mail notifications to a pre configured e-mail ID |
                     | forward-to-switch | Forwards the messages to an external server |
                     | snmp | Logs an SNMP event |
                     | syslog | Logs an event to syslog |
                     | default | Performs the default action for the event |
                     | off | Switches the event off, when the event happens, and no action is
                        performed |
                     | on | Switches the event on, when the event happens, and the configured action
                        is taken |
