no
            - Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
- Service Platforms:
no [adopter-auto-provisioning-policy-lookup|adoption-site|alias|application-policy|area|arp|auto-learn-staging-config|autoinstall|bridge|captive-portal| cdp|channel-list|cluster|configuration-persistence|contact|controller| country-code|critical-resource|crypto|database-backup|device-upgrade|dot1x| dpi|dscp-mapping|email-notification|environmental-sensor|events|export| file-sync|floor|geo-coordinates|gre|hostname|http-analyze|interface|ip|ipv6| l2tpv3|l3-lite-table|lacp|layout-coordinates|led|led-timeout| legacy-auto-downgrade|legacy-auto-update|license|lldp|load-balancing|location| logging|mac-address-table|mac-auth|mac-name|management-server|memory-profile| meshpoint-device|meshpoint-monitor-interval|min-misconfiguration-recovery-time| mint|mirror|misconfiguration-recovery-time|mpact-server|noc|nsight||ntp| offline-duration|override-wlan|power-config|preferred-controller-group| preferred-tunnel-controller|radius|raid|rf-domain-manager|router|rsa-key| sensor-server|slot|spanning-tree|timezone|traffic-class-mapping|traffic-shape| trustpoint|tunnel-controller|use|vrrp|vrrp-state-check|wep-shared-key-auth| service]Parameters
no <PARAMETERS>
                     | no <PARAMETERS> | Removes or resets the logged device‘s settings based on the parameters passed |
      Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated
ap505-13403B(config-device-94-9B-2C-13-40-38)#no area
ap505-13403B(config-device-94-9B-2C-13-40-38)#no contact
