802.11r is an attempt to undo the burden that security and QoS added to the handoff process, and restore it back to an original four message exchange process. The central application for the 802.11r standard is VOIP using mobile phones within wireless Internet networks. 802.11r FT redefines the security key negotiation protocol, allowing parallel processing of negotiation and requests for wireless resources.
Enabling FT standards provides wireless clients fast, secure and seamless transfer from one base station to another, ensuring continuous connectivity.
fast-bss-transition {over-ds}
         | fast-bss-transition over-ds | Enables 802.11r FT support on this WLAN
nx9500-6C8809(config-wlan-test)#fast-bss-transition
         nx9500-6C8809(config-wlan-test)#show context wlan test ssid test vlan 1 bridging-mode tunnel encryption-type none authentication-type none fast-bss-transition nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Disables support for 802.11r FT on the WLAN |
